tRidiot
- Joined
- Dec 21, 2011
- Posts
- 363
- Reaction score
- 283
So my pass window has been a PITA for years. It binds up and stops, especially when it's cold out, or even 'cooler'.
So I have a window rollup module on my alarm which allows me to just 'tap' it to roll completely up or down and not have to hold the switch. The problem is, it doesn't allow me hold it down to keep overriding the automatic shutoff when it 'binds'. So I have to keep tapping it to make it go up a half-inch at a time if it's cold out. In fact, last time I checked it, it took me 47 tries to get the pass window to roll up all the way.
Also, the driver's side started giving me similar problems in the cold, though to lesser degree.
So I'm putting in a new motor and the trans is rebuilt, too. I'd like to fix these windows while I'm at it. I did some research on the regulator, thinking this was what I need, but now I'm wondering if I shouldn't just pull the door apart - which is a major undertaking in my truck, the doors have been sealed and deadened heavily for audio stuff - and replace the motor and spray some silicone in the tracks and cables and such. I THINK the motor should be easy to replace, whereas the regular might be more complicated.
What do you think? It seems to me it is most likely the tracks and cables have a spot that is binding and the motor has gotten weaker over the years, so changing the motor and lubricating the heck out of the other parts might make a difference.
Some of the parts on RockAuto say they're actually built to higher standards and upgraded parts as compared to the OE stuff. Can anyone vouch for this or should I just go back with OE?
TL;DR
Rear windows are great. Front pass has always been a problem for 10y since I got this truck and the last couple years has gotten worse. Driver's front is now getting slightly worse.
TL;DR
