Window rollup - should I replace the motor?
tRidiot
So my pass window has been a PITA for years. It binds up and stops, especially when it's cold out, or even 'cooler'.
So I have a window rollup module on my alarm which allows me to just 'tap' it to roll completely up or down and not have to hold the switch. The problem is, it doesn't allow me hold it down to keep overriding the automatic shutoff when it 'binds'. So I have to keep tapping it to make it go up a half-inch at a time if it's cold out. In fact, last time I checked it, it took me 47 tries to get the pass window to roll up all the way.
Also, the driver's side started giving me similar problems in the cold, though to lesser degree.
So I'm putting in a new motor and the trans is rebuilt, too. I'd like to fix these windows while I'm at it. I did some research on the regulator, thinking this was what I need, but now I'm wondering if I shouldn't just pull the door apart - which is a major undertaking in my truck, the doors have been sealed and deadened heavily for audio stuff - and replace the motor and spray some silicone in the tracks and cables and such. I THINK the motor should be easy to replace, whereas the regular might be more complicated.
What do you think? It seems to me it is most likely the tracks and cables have a spot that is binding and the motor has gotten weaker over the years, so changing the motor and lubricating the heck out of the other parts might make a difference.
Some of the parts on RockAuto say they're actually built to higher standards and upgraded parts as compared to the OE stuff. Can anyone vouch for this or should I just go back with OE?
TL;DR
Rear windows are great. Front pass has always been a problem for 10y since I got this truck and the last couple years has gotten worse. Driver's front is now getting slightly worse.
drakon543
all aftermarket stuff will generally say meets or exceeds oe. generally for what your saying the window is doing i just apply some grease to the tracks and the problem is fixed. only other thing ive had to replace is the side felt sliders. after a period of time the felt like material will rub away leaving just rubber which catches on the glass. rarely have i ever had to actually replace a motor.
tRidiot
tRidiot
The side felt sliders...
I wonder if that would make things better. $32 for one of those.... $80 for a reg.... $40 for a motor (but $80 for the rear????)....
adventurenali92
Big Bear Lake, ca
You COULD just replace the motor, and not the regulator. And then the regulator could fail.... if tearing apart your doors is a major pain you may as well only have to do it once. Replace the regulator felt and motor while you’ve got it all apart, and just call it a a day and not have to tear into it more than once.
91RS
GA
Some of the parts on RockAuto say they're actually built to higher standards and upgraded parts as compared to the OE stuff. Can anyone vouch for this or should I just go back with OE?.
No, it isn't. Have you actually compared aftermarket stuff to new OE? The aftermarket parts are all visually inferior quality and if you use it long term they wear out at least 2x as fast (especially steering and suspension parts). You're not saving any money. I've seen the aftermarket regulators and they're horrible quality, the aftermarket motors don't even have the right connector on them so they have a jumper harness. Buy the OE regulator and motor (last I checked the motor comes with the new OE regulator) and be done. I've seen plenty of these trucks with this issue over the years and new regulators and motors fixed every one of them. The motor gets weak and the regulator cables stretch and the rollers get dirty from 20 years of dirt in the doors.
drakon543
that was my point i was just stating they all claim they are as good or better. i should have filled the rest of that in.
Bill 1960
Testing the Limits
In mine the front track the glass slides in is damaged and bent from some incident. Found some broken glass inside the door when I opened it up. Not saying that’s your problem, but if it’s your first time getting behind the sound insulation you may find anything.
My window is functional but slower than normal. One of these days I’ll have to open it up again and when I do I’ll be prepared to replace the tracks.
I’ve developed the habit of sticking with OEM parts for anything important. Aftermarket is mostly inferior.
tRidiot
tRidiot
No, my doors have been worked on a number of times. I have a major stereo system and we've rebuilt the doors at least 4 times that I know of - from in-door fiberglass pods to now having dual 6.5" midbasses, sealed up door holes with sound deadener sandwiched in aluminum sheeting and a large blocking mat of foam and sound barrier. I am pretty sure during all this we did the silicone spray on things to help, and it did for a while, but never went away.
I think it's time to replace the components - along with sooooo many other things on this 18 year-old truck. <sigh>
Once I'm done with the motor/trans swap, I need a new gauge cluster, these window fixes, new carpet, new seat foam, leather and controls, A/C blend door fixes, minor body work, new paint, brake upgrade with brake lines...
Sheisse, what a list.
S33k3r
Dallas, Texas
Make a build post! :Get him!:
(I also suggest listing information about your ride in your signature -- not a requirement, but it will benefit you later I am sure)
Joel Ragan Young
Other than binding in the tracks and the other possibilities mentioned, I improved functionality by cleaning the contacts in the actual window switches in the driver's door pod. The interior panel must be removed in order to access all of the screws holding the switch pod in the door panel in most years, but the pod is easy to open and clean under the rubber membrane and circuit board. All the gunk and build up in the contact pads had made my passenger windows operation intermittent, but the results were spectacular.
latvius
Ariton Alabama
Window motor with regulators are cheap and easy to r&r, I would have replaced them long ago if they gave me the grief yours have.
Art Karlson
TL;DR
Art Karlson
TL;DR
I replaced mine last fall. It was very easy and rock auto had the parts to me quickly. I did replace everything and lubed it well
There was a video on youtube that was well done and easy to follow
tRidiot
tRidiot
I did buy a pair of Dorman regulator and motor combos - both passenger side windows should be fixed before I leave for San Antonio on Friday. :D
That is... IF I can get my lazy arse to DO it!
tRidiot
tRidiot
Well, I gave up on pass front - worked an hour and a half, but the baffles for my door speakers were a helluva lot more difficult to get into than I thought. My install guy definitely built them to be solid. I'm gonna have to do that window regulator someday when I have an entire afternoon to dedicate to it. <sigh>
tRidiot
tRidiot
At least one good bit of news - my son helped me last night replace the rear pass window motor, it now works perfectly. Used a Dorman replacement for about $83. Original wouldn't move from fully rolled up, so getting it out was a little tougher, but I managed.
It was a good lesson for my son in how to manage it, too, that would probably have been a $250 job at a shop. Pretty easy all in all, and I don't have to smell his farts when we're on our trips over the next two weeks! He can finally roll that window down again! lol
