Wheel project: Black or color-match?
I like them as they are but if you paint them, def go greystone
Agreed.
I have stared at the pics for some time and think either color match the greystone or go to a matte black that matches the color of the running board black.
The running boards should be glossier. They're just dirty and I'm too trashy to care at the moment. I wanna clean 'em and put that stuff on there that another member used recently that makes the black look new, but I can't think of the product.
He probably did a 3rd gear burn out right before putting them up for sale!
Possibly! After all, his truck was in the shop getting a new trans...
Hi
You could go a flat/matte metallic of your body colour that would compliment both your colour scheme and the black addition present and pending?
Sent from my SM-G950F using Tapatalk
Indeed. I'm considering testing this- body color with no gloss clear coat versus regular high-gloss.
Probably rides rough and tires that fit will be xtra expensive and you won’t know for sure until it comes time to mount and balance the tires on them. Then fitment in that wheel well and turning what kind of offset are they and are you going to scrape? Lots of unknowns and risk cost.
Not really any unknowns, actually. I'm well aware of what I'm getting in to. I'm counting on them to ride rougher than my 20s. I had 22s with Bridgestone (AKA "Brickstone") Duelers. Factory wheel and tire package from a 2019 Tahoe RST. They were harsh, but tolerable. Good tires (such as Michelin LTX) ride nicely for the size. Yes, bought new, the tires would be pretty expensive, but I'm a deal hound. I've already calculated the fitment with my drop and the 22s I had on it since the day I dropped it. I have very minimal rubbing issues and can easily fix them. But they're so minimal that I haven't bothered. 285/45-22 is the standard factory replacement size for the 20" options. If it was acceptable on a vehicle from the factory, then it's good enough for me. For being lowered and with plans to go a little lower, I want a slightly smaller and narrower tire, so I'm wanting a 275/45-22. It turns out that this is a factory size on a few new vehicles. I have a lead on a set of Pirelli Scorpions off a 2021 F150 with 2,980 miles on them. If all goes to plan, I'll get the whole set for less than the cost of one new tire.
I’d CM them with clear over the top, just like the body. Or go black. Otherwise it will look like you tried and failed with no clear. I did a set of headlights with no clear coat and the color looked so much different it was crazy, I decided to clear them and they looked right. I feel it would be the same with the wheels. Either the same exact as the body or something contrasting.
kbuskill
NE. FL.
Agreed.
It sounds like you already have things figured out with the tire size. It also sounds like you already have a deal lined up on some tires.
I was just going to add that I was running 285/40/22s on my Burb when it was 4/6 dropped with almost zero rubbing.
The 275/45 is slightly taller at .7" overall height, .4" sidewall, than the 285/40 but also narrower by .4".
My thoughts as well. I wanted black to contrast, just like the grille, but then decided to make them match. So, I should make them MATCH. Although, I'm thinking of making the hoops behind the spokes gloss black. That'd save on the expensive paint, give a little contrast and might make the centers look larger if that step in the center of the hoops were less noticeable being black.
PeteCT
You mean if they were Graystone and gloss to match the body? I'm thinking the current color looks like I'm trying to CM but failed. I wonder if they'd look the same if I sprayed 'em Graystone, but used a matte clearcoat.
Certain designs designed for specific colors. For example, my new rims would look suck if they would be black, or polished metal but the mix works just right.
Wheels you got, have specific style and color serves them right. If you want another color I would change the wheels.
I'm grasping at tiny straws with the tires size change. But, most 285/45-22 I find around here are cheap brands or Brickstones that were taken off in favor of better-riding tires. The 275/45-22 Pirellis seem to be on-par with the ride quality of the Michelins. They cost about the same new, so they're a deal no matter what. I'll be doing some clearancing cuz I aim to have no or almost no rubbing with my desired drop on a nearly-stock-size tire. The 275/45-22 is only .2" shorter than the stock 275/55-20- a mere .6% difference.
Nah, they'll be gray. I like the design and I already know they'll good in that color. Gray it is, final answer.
PeteCT
if you are okay them to look "painted", why not. they will look newer I guess.
Keep the wheel you have now and sell those.
The declads? I already sold the RST 22s to my neighbor. He had a new/used, but matching tire mounted on the repaired one. It balanced perfectly fine and is holding air just fine.
I'm definitely keeping the declads. I have plans to paint em after I get the "new" 22s on.
Progress! A local tire shop wanted over $77 to remove and dispose of the trashed tires that came on the wheels. Walmart would've been about the same price. Pep Boys wanted nothing more than my appreciation, so they got the job. I slipped the tech a 20, though. Being a former tire guy myself, I had an honest appreciation for his services. He knocked 'em out in ten minutes, too.
I handled it between service calls, so they're in my work van:
An unexpected surprise. Can these be tested with no pressure on them?:
Scored almost new (3,000 miles) tires for them in the oddball size I specifically wanted for $380:
HiHoeSilver
Away!
Chicago
I'm curious how this would look...DO IT.
After much consideration, I believe I will paint the whole thing, including the milled edges. This would fit the overall scheme better and it'd be easier than trying to mask off those areas. So, body colored spokes and outer lip, gloss black hoop behind the spokes. That gloss black would soon get dirty and mostly stay dirty, so it'd be "hidden" anyway. I just gotta determine where the black will start in the hoop. It'll probably be at the step to have a dividing point that makes sense.
First is to build a rig to spin the wheels so I can "machine" them. Bolting them to the axle and running it in gear isn't so enjoyable any more since I don't have cats.
briqsay
Wisconsin
Yesterday, I ended up with a set of these 22x9.5 Verde V24 Invictus wheels. I mounted and spun each of them on the front to check for bends and looked 'em over as close as I could for cracks, etc. All looked well so I brought 'em home. They need some minor reconditioning which will include paint. I had planned on gloss black with whatever wheels I got. But, these, being a matte gray, are close enough to my Tahoe's Graystone Metallic to get me thinking.
Here they are mocked up. I positioned them to hide the spokes of the de-clads:
The "concave-ness" doesn't show as much in the pic, but the spokes angle inward a decent amount, which I like. The other point of this pic is to show the milled edges of the spokes:
These wheels are available in gloss black and they look good. But, the more I look at these pics, the more I'm thinking I wanna paint 'em Graystone. I'll keep the milled edges, though. Other considerations are painting the hoops black, maybe all the way to the lips. Also, since the lips will be getting some "machining" to fix some mild rash, they'll look like the milled edges. Do I leave them machined or paint 'em? I have plenty of time to ponder this. First step is to get the junk tires off.
Durobans
