Possible e85problems?
scotto0609
My recently purchased 03 z71 sub is e85 capable, and I’m curious? Should I give it a try or not? The truck has 200k on it is running well with no codes. I have never used the stuff and don’t even know where I can get it. Thoughts? Thanks
HD_LS
I think the ultimate is to have an e85 capable vehicle (for the extra ethanol resistance of all the fuel system components, and extra flow capacity), and then not use e85. :)
R422b
Oklahoma
That's pretty much what I do. My 2002 Tahoe is the 85 capable and though I have used it once or twice out of curiosity I was not impressed and I did the cost per BTU math and figured out that gasoline is cheaper so I don't use it anymore. My understanding is that 85 in a stock engine will never pay off. The fuel cost more per BTU and you get poor efficiency from it so unless you have a vehicle that requires high octane fuel 85 is not worth it.
Sent from my moto g(7) play using Tapatalk
01FormulaTA
wouldnt hurt to run a tank every now and then, it should clean some of the carbon deposits on the pistons and the valves...it burns much cleaner than gasoline and will give you a slight increase in performance...depending on what E85 costs in your area the price difference could offset the decrease in mileage, I run E85 exclusively in my truck and have never experienced any issues, I average about 13.7 mpg but its not an apples to apples comparison (my truck has a 6.0 swap, 11:1 compression, cam swap etc.)
R422b
Oklahoma
That's where it pays off. With a modified engine. My Tahoe goes from 18 mpg to 12 mpg on e85 because it is stock and can't take advantage of the higher octane.
petethepug
Michael
SoCal
Pretty sure that GM could claim 403hp on the L9H vs the L94 385hp in the early 07-08 Tahoe/Yukon was that they ran them on e85. On petroleum fuel they don’t behave the same.
It does wake up the motors on the NNBS trucks that can run it.
Run it! But don't try a tank or two and go back to gas, you'll never notice the benefits as the alcohol content will be too low until about the 3rd or 4th tank and the drivetrain adapts to it.
Download the Gas Buddy app to your smart phone and then you can look around and see who carries E85 or E15 and possibly what the current prices are (only stay up for 48 hours).
One word of caution, your truck has an actual sensor to measure the alcohol content and they do go bad. I do not know if trigger a CEL when they fail. Check your shop manual or ask around.
My truck gets its best mileage and lowest operating cost when mixing gasoline and E85, between 16-22 percent or so. To get that, I pump aboard 6 gallons of E85 and 20 gallons of gasoline. If the station has E15, I'll pump about 3-4 gallons of E85 and the rest E15/88. Mind you, my tank is 31 gallons.
My engine is stock save for a gasoline tune, it runs on stock E85 tables.
mattbta
Frisco, TX
For the first time in 16.5 years of ownership, I've put more than one tank of e85 in consecutively. Need to pull my VXDIAG out and look at ethanol %, but it's noticeably peppier around town. I like. And since i've only put 1000 miles on it in a year due to WFH, not concerned about the MPG. :vroom:
Mudsport96
40.923,-89.488. Illinois
One thing ive learned recently, to touch on your tune comment. There are modifiers in the flex fuel computers, not an actual " e85 tune". This surprised me but kinda makes sense.
To make it as easy as i can explain it, the flex sensor reads the alcohol in the fuel the adds fuel and timing to the GASOLINE tune to compensate for the added ethanol. So, having a gas tune gives you a slight e85 tune in a way
I didn't know that, thanks!
HACK BLOCK
NYC
I run e85 a lot in my 2011 Denali and when doing the math when it comes to cost/mpg the e85 works out better for me
Charles Bradley
I agree! I have a 2007 Chevy Tahoe with 167000 mikes on it. I have only found one gas station that sells it in my area and sometimes that gas station is out of reach. The e85 runs out a lot faster then regular gasoline does so I no longer use it!
HeavyHoe03
