Anybody happen to know where the sunroof drain lines exit out at? I shoved some weed whacker line down there got about 8" more in on the driver's side I think my passenger side is clogged been having a water leak on passenger side, trying figure out where the exit is so I can see wth is going on
Anybody happen to know where the sunroof drain lines exit out at? I shoved some weed whacker line down there got about 8" more in on the driver's side I think my passenger side is clogged been having a water leak on passenger side, trying figure out where the exit is so I can see wth is going onView attachment 276763
found the video for a traverse or whatever it is which shows them exiting the door jamb, but ours must come out inside the quarter panel/fender somewhere, I can see it under the dash where it turns inside towards the fender. o'well
I thought it was next to the ac condenser drain.
maybe, it comes from under the fender somewhere I poured water down both sides and both sides work fine, I suspect my front windshield has a bad seal then because water comes down the inside of the windshield on the passenger side when I go thru a car wash or when it rains because I park with the nose down in the driveway. and water ends up on the passenger side floorboard all the way to back seat, I need to have the front windshield replaced anyway I got a nice rock in it about a week after I bought and nothing since :mad::mad::mad: probably be my luck to go replace it and turn around and get another rock.
It rains in Cali?? Strange.....:D
ordered some of this tape to maybe put in the lower door jam's to cover the scratches in the paint, see how it looks when it gets here
looks better than some of that fake composite crap
https://www.ebay.com/itm/4-x-10-Non...Anti-Slip-Sticker-Grip-Safe-Grit/292881735032
I bought that and returned it because I was thinking that when I try to wash that area it would grab the rag or sponge. Plus I think it will attract dirt and shit. I went with a vinyl that wasn’t non skid, just textured. I can’t copy from Amazon app on my iPad so I don’t have a link but if you search for Trimbrite T9021 body guard kit you’ll find it.
BG1988
I put a 256GB sd card in. This way, by the time I figure out that I need to look through the videos, I should have a pretty good cushion.
it comes out just behind the wheel well door jam and fender meet (wheel well cover thing)
so that will have to be taken off to get to it..... most likely you will also need to pull the tire as well
I just checked it's the same for both sides....
loose hose or damage hose?
no, I think the seal on the upper right area of my windshield is bad, I will get it replaced soon and find out for sure, nothing else it could be all the door seals have been replaced already, the water comes in and runs down the inside of the windshield
BG1988
the hose is damaged then if it's leaking inside
you have checked the sunroof frame for cracks it's plastic i think this can happen if there was unnatural body flex i.e accident
bbl
bbl
poured water in the sunroof tray, drained out the holes like it's superposed to, pretty sure the windshield seal is bad it's not that uncommon. Headliner is not getting wet
