2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Just have @randeez come over. He'll weld that exhaust on for ya, no problemo. He has been practicing ya know.
Those bits are cheap compared to the old days. Good to know they are not a pile of shit. Looking forward to your solution. The bottoming out/clank sound would drive me nuts.
His welds probably look better than mine, welding on round stuff is annoying.
I was shocked at how good they are for the price! I only ended up using one bit yesterday and it showed no signs of wear, I did dip it in Bar/chain oil every so often but I gave it every bit of RPM my little cordless Dremel could muster. The bottoming out isn't that terrible its more annoying than anything, need to get an alignment scheduled again.
Sam Harris
I have about 8' of 2" diameter .375 thick DOM (I think) in my scrap pile. Just don't know how in the hell I would make it not look like total dog shit. I suppose cut the cross member flat and plate the ends with some 3/16s then weld the tubular cross member from plate to plate. However, there's no way to get the tailpipes out of the way without cutting them since the closest joint is in front of the big Flopro. So either way it seems the tail pipes would need to be removed/reworked.
**Edit** Didn't see your pictures until after I posted. That would work great If I was going from frame rail to frame rail but, I think the important thing is having something connecting the body mounts so they don't try to sag down or break off.
Just make it a Bluetooth connection..!
(Credit for this comment goes to VGG)
pwtr02ss
Tennessee
Practice makes perfect in the welding department. Like Randy, you too can learn to weld with a few simple adjustments here and there:cheers:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
What app do I need to download? :jester:
I'd be more apt to practice exhaust welding if I wasn't laying on my back with my face inches from the weld lol.
Storytime: Long ago I did an exhaust hanger repair for an old supervisor. I was laying on my back under his Frontier in the dirt holding his exhaust up with my left hand and using my right to try and reweld the hanger. As I pulled the trigger a huge blob of slag landed on my chest, burned through my shirt and skin causing me to drop the mig gun and let go of the exhaust. The exhaust then bopped me in the head and left a nice scar on my fore head. Had I not been so poor I would have had a welding mask instead of Harbor Freight welding goggles, the mask would have probably saved my face.
randeez
south florida
the welds look great if you dont look at them
i'll post some pics of V2.0, its still pretty ugly. but in between all that there are some good beads laid 2" at a time. would need some sort of turntable or lathe to be able to run it any better around tubing, it is annoying as said
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
i'll post some pics of V2.0, its still pretty ugly. but in between all that there are some good beads laid 2" at a time. would need some sort of turntable or latch to be able to run it any better around tubing, it is annoying as said
Youre doing tig right? I'm not worried about having stainless exhaust so Mig is fine for me. Just turn down the heat and glob on! :head3:
pwtr02ss
Tennessee
Yes, welding on your back or above your head a sucks! When I was younger, I used to cut a little slit in the seam of my jeans at the bottom, you know, like everyone did. More than once I caught myself on fire. Nothing like welding and thinking "damn, that light is warming up the leg nicely" followed quickly by "oh shit!"
pwtr02ss
Tennessee
Every time I hear someone say that I cuss my dinky Hobart Handler 140. Poor ole girl has just enough balls to burn clean 3/16"
Shiiiit, thats plenty for some exhaust and a little crossmember notching. I have a little lincoln thats good for about the same thickness. I hate that welder. Someday I'll pick up a new miller 252 or something along those lines.
Casey has a mig/plasma thats "eastwood" brand. Its impressed me thus far. I'm not sure who actually builds it or what the longevity will be, but for the money, its really not a bad pair.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I've heard great stuff from those Eastwood welders, I'd love to get a plasma cutter too but my next purchase will likely be a big boi Tig machine.
The hard part of the cross-member notch isn't so much the welding but getting a grider or something up in there to clean everything up and make CLEAN cuts not jagged shit like I usually do lol. Then of course how to raise the tail pipe into the newfound space.
Def could use a lift to do that job! I thought you had one.
randeez
south florida
Behold...a sample of the quality you're in for
pwtr02ss
Tennessee
much better! Every time you weld, you will improve. In 6 months, you'll look back and these remind yourself of that
if you can hold a continuous bead without burn through, you dont really have to do circles or back forth or whatever, you can just run a straight line. *if it's hot enough to not have roll under and will lay flat
CrackerJack135
