Just Fishing
Can't fix stupid
Utah
I've tried a few and all read 1.5-2 MPH slower than what my speedometer reads. I only bothered in the first place cuz I've noticed that everyone is always pulling away from me even when I have my cruise set dead nuts at 80. Before my tune, cruising at 80 had me steady with the flow of traffic. I just assumed the tuner uploaded an incorrect circumference based off my tire's advertised measurements on the sidewall. I measured it with a wire and the difference was 18mm. I corrected it and it seemed to make it worse. So, today, I changed the number 2.5%. The damned app STILL reads 1.5-2 MPH slow.
That's weird, i find those gps apps are spot on.
When i did the c5/c6 brake conversion on my vette, i also needed bigger wheels.
To get the speedometer working correctly i also need to change a little gear.
The vette uses a mix of analog and digital.
The gears are hard to find and sometimes expensive...
Using an online calculator, and finding the tire actual outer size, i made the order.
Gps reports exact match at all speeds.
Where I'm going, i would assume the speedometer reading would vary wider at higher speeds if it were wrong.
Gps app confirmed a match to my speedometer while going 20-infinity
:D
:angels2:
avalonandl
Troy, MICH & Naples, FL
I’m just doing a simple battery swap in the Silverado. The tender tried to save the Super Start that’s in it but it didn’t work, so I’m going with an Interstate AGM. This is a bit harder than most trucks I would say.
Make sure the new tender has a desulfarator mode- Batteryminder tenders have this.
08z71bgm
Long Island, NY
Lots of free cell phone speed apps.
I used one to see the top speed of my boat, took an old cell phone and used tape to strap it to an rc car to see the top speed, and always fun to see how fast you're going while on an airplane.
I have also heard nothing but good things about the draggy. It’s expensive though.
Dicked around with "harmless" changes to the tune. Changed the TCC apply/release speeds, mainly to restore lockup in third, as advised by @pwtr02ss. I just copy/pasted my factory tune stuff for that one table. I don't know why, but the "clutch dump" feeling when the TCC locks in OD is gone or much less pronounced. I may lower the release TP%, though. Also tweaked the tire circumference 2.5% to alter the speedo. I need to get a cop to radar me one day. Or drive next to a Civic or some other car that has a giant digital speedometer that I can read.
just open waze on your phone it has a built in gps, set cruze and compare it your speedometer.
08z71bgm
Long Island, NY
So I’ll be making an order soon with rock auto and looking for motor mounts and pads and I’ll prolly end up getting the same wheel hub as the other side but from there not the store.
I need an excellent stopping pad and don’t want ceramic. I don’t care about brake dust. I’d rather stop and not have fade. No power stop suggestions. Had my fair share over the years. No more. I will also be towing with it so there that.
also need a cv boot. Axle is fine but need to replace the boot it’s torn. Is there one that’s better than the rest?
Can you mix the h2 and stock MM? I only want to change the one I also don’t want to spend 200 on a single OEM MM.
Looks like I will also need to do all the PS hoses and cooler. Any suggestions for that? Might even need the pump. Fluid smells a bit burnt and is slowly leaking. Cooler looks like it’s ready to turn to dust.
carbon fiber is best but there noisy and tons of dust
08z71bgm
Long Island, NY
Dust used to be a concern for me but not anymore since I got my SS. Car stops amazing with the OEM pads and creates a shit ton of dust. I’m over it.
do you have those type of pads on your truck?
pwtr02ss
Tennessee
I'm going to go back with the Genuine GM rotors when I replace them next time. Those seemed to hold up the best. Pads, I'm not sure.
I replaced a CV boot one time. Just used whatever rock auto had at the time. I don't think it matters
Power steering components are as follows (Thanks to @kbuskill )
https://www.amazon.com/gp/product/B0026M9AL0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 just measure your factory hose and cut to length. Move loom over to new hose as well (Replaces GATES 352181)
https://www.amazon.com/Gates-352182-Power-Steering-Hose/dp/B00QKWZPSY pressure hose
https://www.amazon.com/Gates-352183-Power-Steering-Assembly/dp/B00FYF4YE4 return hose
I ordered pressure and return hose from Rock Auto, the cut to length from amazon (Cheaper that way)
https://www.amazon.com/gp/product/B0049Z6VDM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I bought this pump from amazon
As far as mixing mounts, I don't see what it would hurt.
https://www.amazon.com/ACDelco-2584...s=25847739&qid=1618238176&s=automotive&sr=1-1 you'll need two of these if you replace them both. They are the H3 passenger side mount. I also ordered those form rock auto
That's one I haven't tried. I'll give it a shot. Knowing my luck, the three other apps I tried all used the exact same algorithms that may have been flawed. Or maybe it's my phone that's flawed. Or the cellular network in my area.
Altered gearing and tire size will throw off a speedometer exponentially. The odd thing is that these cellular GPS apps were consistently 1.5-2 MPH regardless of speed.
I'm going to go back with the Genuine GM rotors when I replace this next time. Those seemed to hold up the best.
Word. After a poor experience with cryo-tempered PowerStops, I had my GM rotors resurfaced and they're still smooth as buttah to this day. I could have better pads (Basic GM something- Amazon deal). But, I don't feel endangered with them and I'm not [officially] autocrossing my Tahoe.
pwtr02ss
Tennessee
Thought it was h2 mounts not h3.
Me, @iamdub , and apparently @Just Fishing have the H3 mounts. They worked perfect on my truck. Direct bolt on
here you can kinda see the part number/fit
I used them briefly for a few months, they make a lot of dust and squeak like hell but they do stop you. Now I am using the new Duralast elite copper-free ceramic, they work quite well, no dust at all, silent, once those wear down I have set of the Baer eradi-speed 15" rotors to put on with a new set of the copper free pads, I just can't bring myself to spend $4k or more on brake upgrades I'll just push my foot harder lol
the_tool_man
Upstate South Carolina
As others (including myself) have repeatedly stated, the solid mount's original use was as a PS motor mount on a Hummer H3. The GM part number is 25847739. This same part number will fit both sides. I bought two, and a trans mount, with the intention of replacing them all. But I've only replaced the DS so far (original was ripped almost in half).
Things may have changed. But when I tried to get the parts, they were on national backorder. I had to go through three places to get them ordered. I finally found an online dealer that got them to me. But I had to lie and give them a VIN from an H3 before they'd take the order.
Replacing the DS mount took me about 2 hours. You can find details on the swap elsewhere in this thread, when I did it not long ago. The PS looks to be quite a bit more challenging.
The solid mount does transmit more vibration at idle. It's noticeable on my truck. But I don't know if that's normal, or indicative of some maintenance I need to do. I'm working through that process now. Even if it turns out to be inevitable, I'll take it to avoid replacing the mount again.
kbuskill
NE. FL.
I thought my post earlier would have cleared up the confusion... where I said...
Just to clear up confusion.
The mounts that fit our trucks are for the passenger side of the Hummer H3 Alpha, which came with the 5.3l. You will need two passenger side mounts to replace both mounts in our rigs.
And they work beautifully I might add.
I guess perhaps my message wasn't clear...o_O:D
HeavyHoe03
