285/70/18, another willitfit thread NOT sorry!
ItstheHOFF
Henderson, NV
Hey y’all, I found a good deal on some Nitto Ridge grapplers in 285/70/18. That’s barely larger than what I have now which are 275/70/18 toyo open country and no issues except them wearing funny. Just wondering if they’ll even fit my leveled 2016 suburban without rubbing. Anyone have this size? Got a definitive chart of go/no go sizes that will fit our trucks with levels? Please share!
Jeff_
Scottsdale, AZ & N. Idaho
1. Are you on the stock factory 18" wheels?
2. Pics of current setup?
I'm interested in the same. Been waiting to get some 275/70/18 tires but would consider 285/70/18 if they fit like you're wondering as well.
ItstheHOFF
ItstheHOFF
Henderson, NV
It came with these XD chromies. I don’t know the offset but I’m pretty sure they’re 18x9. Can’t wait to swap them out.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
Durobans
