Check reverse lamp
Thomas Schneider
Yukon, OK
Picked up my Tahoe Z71 on Thursday and noticed the same thing when I got home and shut it off; didn't think much of it at the time. Thanks for the FYI. Keep us posted if you find out anything more. Hopefully it's just a software glitch and now that this vehicle has the "Over-the-Air" software update capability, maybe we won't have to bring it into the dealer to do it!! Let's hope that's it!
Big Mama
Virginia
No updates but you may want to check the service bulletin to see if there’s a projected fix date.
Thomas Schneider
Yukon, OK
Still nothing that I've found. Just thought I'd update the post with pic of what we're talking about and copy of TSB.
Thunder22
Thunder22
thanks... i'm just in the habit of dismissing it when it happens intermittently.
Ndegoede
I replaced my reverse lights with new LEDs and started to see the issue. Just got suburban 10 days ago.
I figured it was an alert due to the lower voltage the LEDs are drawing now but maybe not. Thanks for the heads up
Thunder22
Thunder22
I just spoke with service and there's a reprogram available for the light control module. I"m having it done on friday morning and will update the thread with results.
Thunder22
Thunder22
Had the update done today. No surprises and no re-occurrence of the check reverse lamp message. Also had the recalls done.
Thomas Schneider
Yukon, OK
Thanks for the update. How long did it take? I'm just trying to figure out if this is something I can wait on, if reasonable, or if I'll be needing the wife to come pick me up.
Thomas Schneider
Yukon, OK
Went back to the dealer today to have them finish up recalls that had parts on order and told them again about the "Check Reverse Lamp" still showing up and gave them a copy of PIT5777 and told them about TSB #21-NA-044. I didn't read the paperwork before I left and the minute I shut down after backing into my garage, there it was again!! Now, after a closer look at the invoice paperwork I see: "No Message Found." I guess they expected it to throw a code??
What does it take for these people to get it?? I guess it's time to switch dealers, get back with the service manager, or just live with it!
Bob LaFord
