97 Yukon won't shift right when ABS light is on
RGreen
I've had a couple of incidents where the ABS light comes on on the dash, and then the transmission won't shift properly. It happens on cold, wet days. I've been told that this vehicle (97 GMC Yukon 4WD 5.7) does not have interface between the transmission and the braking system, yet it's happening. Anyone have any ideas, questions, or things I can check? The only codes the transmission shop said they found were C0036 and C0037, but of course it did not give them any problems when they drove it.
exp500
Those are wheel speed sensor codes for front. Has any work been done to the wheel areas around the time the codes began? You can try replugging the sensors, and if you are over 125k miles you are a candidate for new hub bearings and sensors anyway.
Bill 1960
Testing the Limits
Are you seeing any loss of power when the light comes on, as if the ABS system thinks it’s really losing traction?
exp500
If he is in 4auto could be his issue. If he has NP-246, 2wd should only be a nuisance light.
Grounds are a problem on ANY vehicle. Worse in rust belt.
RGreen
RGreen
I was able to drive it home by manually shifting from low gear to drive. Didn't seem to have any problems when I did it that way.
RGreen
RGreen
Haven't had any work done in the front. I bought this as a used high mileage fixer upper. You're not the first to suggest the hubs.
exp500
RGreen- post a pic of your RPO codes from glove compartment. Or look at Tcase see if it is NP246.
And unplug/ clean /replug near frame/upper control arm. Clear codes, see if it comes back.
It is about 3 hour job to change both sides, Check ball joints and axles first, because if you are that far apart and it needs them, do it then.
RGreen
RGreen
I have a
I have the 272 transfer case.
RGreen
RGreen
No lo
No loss of power. Whatever is happening it is making it not engage the torque converter lock up. Almost as if it is slipping.
exp500
Look in the service manual or maybe even in the owners manual. Does the 4 auto use the brakes to control wheel spin? Or is it the Trans /Tcase? Either way you got some fixin to do. Recommend don't drive it or trans troubles quickly.
CRN_25
