Cabin Air Filter Retrofit
kbuskill
NE. FL.
Millennium Falcon
CA unfortunately
i dont think a rotozip will fit. they are pretty large, atleast the one i have is. I used a lighter and warmed up a razor blade and it cut right through it real easy. Gave me a nice clean cut too
dremel makes a huge mess.i tried that to start and it flung burnt plastic chunks all over and you have to go just right because too fast and it melts back together, too slow and it melts too much and gets all goopy
I used a Dremel with a small cutoff wheel. It’s too small really, the disk loaded up with hot plastic pretty quickly. I’m going to try the hot knife when I do theothertwin in a few days.
I used a Dremel with a right angle chuck and a small grinding wheel. For the areas that I could not get to with the Dremel, like making clean corner cuts, I heated up a utility knife blade and cut through it.
Yeah, that's what I figured with the Rotozip. Plus, I would have to figure out a straight edge to run the RZ along to keep me cutting in a straight line.
I wasn't real keen on the Dremel/cutoff wheel idea, either. The plastic of the HVAC housing seems like it's the sort of plastic that would be a messy PIA. Thanks for confirming that, Geoff and Rex.
I bought a hot knife a while back to try on this, but I just haven't gotten around to using it. Sounds like it might work. I think I'll do my parent's Yukon, first, and let them be the guinea pig.
Thanks, guys.
Thanks, guys.
As I recall, the cutout lines for all 4 sides of the cutout are already visible on the plastic housing (since it was included as OEM in previous years), so there is no need to use a straight edge to guide your cut.
Exactly. There’s a groove where it needs to be cut, that’s why a good utility knife works. Just don’t try to cut all the way through on the first cut, score it a few times. It’s pretty easy imo.
Millennium Falcon
CA unfortunately
I should have clarified myself a bit more. I meant that I would need a straight edge to keep my cut running in a straight line. I can't freehand a straight line with a Rotozip to save my life.
Davidj281
I bought a <$20 soldering iron sized hot knife for this and some cut up and taped hacksaw blades to do it. Hot knife is way to go as long as it’s like a soldering iron with an xacto blade tip. It’s real awkward area to get to. Use compressed air if you have to close out the area while vacuuming at the same time.
As @Rocket Man stated above, there is already a groove molded into the plastic, so you already have this groove to guide to keep your rotozip in a straight line during its first pass.
Sobro
Nashville
Mine was a pain in the butt. I used a razor knife and didn't know about heating it up and was making no progress. Then I used a Dremel diamond wheel to make some nice long slots. I learned my lesson about ABS and Dremel cutoff wheels when I made an armrest extension for my Focus ST. Finished with a hacksaw style jigsaw blade vise gripped as a handle.
The Dorman filter went in very nicely and the bolt under the console was omitted when I buttoned everything back up.
Geoffsfas10
St. Louis
I dont think ANYONE can hahaha. Those things are super squirrelly, but its easy to follow as the others have said.
Sparksalot
Bastrop County, Texas
Just finished theothertwin. Just the hair inside the kick panel, and elsewhere since I bought it, I was expecting way more at the coil.
I also found a bonus piece of cable.
702C5DF5-86A8-443A-B962-4803A9F51BBF.jpeg 2E0C50EC-EB6C-44A0-B6A5-DF12E38D0320.jpeg 15B4D6D2-B2C4-4457-833C-08E5BF6DC340.jpeg 1A4DC877-1A9D-43CD-B1ED-9894AA1FE3A0.jpeg 9055C3B8-798F-437F-988E-AC002A1DC913.jpeg
Bill 1960
Testing the Limits
Are those of you that have the cabin filter removing and reinstalling this kick panel / cover every filter change? Or does it go to the extraneous parts bin?
petethepug
Michael
SoCal
It’s cosmetic mostly but will protect the assembly from passengers with size 12 and up.
Hot razor knife, that’s the key! I’m not doing a hacksaw blade this time.
kbuskill
NE. FL.
I kept mine.
It is not only cosmetic and protective but also helps reduce noise from the blower motor.
You can take the 2 screws out that are easily accessible and drop it down and out of the way to change the filter without having to mess with the third screw behind the console... just FYI.
Sparksalot
I kept mine.
I only put two screws back in thecopcar. Right now it’s just sitting in place in theothertwin, since I think I need some actuator attention.
I don't recall removing that kick plate to install the filter. Maybe, my mind is failing me here.
MoundMedic7
