Sparksalot
Bastrop County, Texas
My bag of tools is the rear half of the lower right drawer.
on long road trips I usually take a tool bag of specific tools that would be most commonly needed in a attempt to prevent some ******* from charging me highway robbery in case of emergency.
Got a list? Kinda curious, and I need to do this.
Just Fishing
Can't fix stupid
Utah
Unless your going to build a 1000 rwhp rig, no need for those big twin disc verters.
I got the Circle D 6L80 3200 stall, only option I pony'd up for was the billet where that makes the converter stronger.
Around town, drives like a stock converter...............now when you put the pedal down, its fun. Its like the best of both worlds.
I think that would be about right.
I really think that would fill in the low end grunt void that the 5.3 has.
Many of those converters specify not for towing is my only concern.
Weight of the tahoe + some of the canyons around here.
My boat does not weigh much really, maybe 3k fully loaded with fishing gear and fuel...
1BADI5
DMV
Well I would recommend calling them to place your order. When I ordered mine, I called, gave them my specs and I'm super happy with the product & function.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I know you weren’t asking me but...
Here’s mine.
Truck tool kit:
Bottle jack
Screw driver set or multi driver
Wrenches 8mm-19mm, 1/4”- 3/4”
3/8” socket set
Ball peen hammer
Punches and chisels
Standard pliers
Needle nose pliers
Channel lock
Vise grips
Wire cuter
Electrical tape
Duct tape
Sealant
Penetrating oil
Fire extinguisher
Gloves
no I just hand pick whatever but the normal stuff like 7 8 10 12 13 15 17 18 20 22mm short and long sockets, a variety of ratchet extensions, breaker bar, both types of screw drivers, some open end wrenches basically, duck tape the essentials is all. usually the back is packed with suitcases or equipment and snacks so not trying to add 100lbs of tools
wjburken
Eastern Iowa
When I travel with the family more than a couple of hours here is what I pack.
1 Craftsman 159 piece case of tools
1 jug of antifreeze
1 jug of oil
Brake Fluid
1 serpentine belt
Flashlight/Worklight
Adjustable wrench
Pliers & Vise Grips
Roll of paper towels
Funnel
Gorilla Tape
Zip Ties
Thanks for the lists guys. Every time I go to put a kit together it gets out of hand and I give up. I’ll make a list of my own based off all yours and hopefully it won’t be too much. Maybe if I actually make a list first it will help. I’d like to make my roll-away shrink to pocket size but that ain’t happening.
George B
¯\_(ツ)_/¯
I need to balance necessity with weight and space.
I try to just keep it limited to what I would need to change the radiator, battery, water pump, alternator, maybe a wheel hub. not gonna try and do major stuff in a parking lot somewhere, I have had AAA roadside for like 15+years so getting it towed a distance if needed is no biggie
Yeah I have AAA+ with 200 mile towing but last time when I did my reverse WOT specialty the dude wouldn’t let me ride in the tow truck because of Covid. Luckily I was within walking distance of home but I guess I could have called Uber, they’re operating again. But not sure if the tow companies are letting people in their trucks yet.
I don't see how they get away with that. I'd think it would be a huge liability for AAA.
What, you mean not let people in the tow truck? The tow companies are only paid by AAA, not owned by them. The tow companies set their own policies. Nothing AAA can do about that.
Yeah, letting people NOT ride with them. Didn't someone say a driver said that was AAA's policy but not their towing company's? What if someone gets stuck in a bad area(rhetorical question) and can't get a ride, and the driver refuses to let them get in?
same situation if I broke down with the whole family on a road trip were gonna have to get a rental or something were not all going to fit in a tow truck, most of them only allow 1 or 2 passengers when they do allow them.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
IMO this is a must along with a plug kit. A quality one that won't overheat and take a shit on you:
https://www.amazon.com/dp/B07MMGLNHC/ref=nav_timeline_asin?_encoding=UTF8&psc=1
This shit I carry all the time, fits in 2 milk crates behind rear seat and glove box/under pass/2nd row seats:
Jug of Oil
Jug of A/F
Jug of washer fluid
Run of the mill 100 pc or so tool kit that has pliers and cutters etc
Bag of zip ties
Rags
Blanket
WD-40
Funnel
Tie wire
Flashlight
Heavy pocket knife
Spare bulbs, fuses
Tire pressure gauge
Trim tools
Tow strap with hooks
Heavy, quality jumper cables
Probably a couple other things I am forgetting
I also keep a barbed heater hose connector in one of the heater lines with extra spring clamps on it in case one breaks I can just cut it and connect it into a bypass mode. I don't keep tape in there it seems to melt and get all ****** after a while.
IDK but you have the right to refuse a tow so you could stay in your broke down vehicle if you felt better. You don’t have the right to possibly infect a tow driver with Covid though, they have the right to protect themselves. There’s no way you can force someone to be in a small enclosed space right now no matter what. If you’re that concerned about being in an unsafe place you can call the police I guess. I know there was a time that you couldn’t get an Uber or cab for awhile when this shit first started, and then they modified their vehicles with plastic screens and of course you ride in the back, behind the plastic. You can’t do that in a single cab tow truck, which almost all of them are. I don’t remember seeing any crew cab tow trucks. So right now afaik, you still can’t ride in the cab of a tow truck- you have to call an Uber or cab and it’s up to you to get yourself home. I don’t think there’s anything in AAA’s policies that states they have to take YOU anywhere, just your vehicle.
j_jerry79
