YukonXL04
The Riverboat
Oh cool, well that gives me hope lol. I'm almost to 100k. Hope mine is good to 200k haha.
Hi, how can I check my ride rear axle? It is a Tahoe 5.3 LT ('01 MY) but its sticker does not show those acronyms mentioned in the post quoted below. Thank you.4.10 was available from the factory. Look at your RPO sheet (in your glove box) to see what gear ration you actually have:
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU5 Rear axle, 3.23 ratio
GU6 Rear axle, 3.42 ratio
Sorry to hijack, but Is this the sticker you are talking about? I'm sure my Z71 came with 3.73's, but just thought I would check....View attachment 160438
Yes that is the sticker. You have the GT4 (3.73)
Welcome to the forum from Iowa.Hi, how can I check my ride rear axle? It is a Tahoe 5.3 LT ('01 MY) but its sticker does not show those acronyms mentioned in the post quoted below. Thank you.
Thank you very much from Europe.Welcome to the forum from Iowa.
10R02-0443 11R02-0041 12R03-0058Can you post a picture of your RPO sticker?
Thank you too.GT4 very common both my 2000's have them. Tahoe is a 4X4 Yukon is a RWD.
[email protected]You can also contact GM with your VIN and ask for a build sheet they will gladly give you one that’s what I’ve done a few times before going to look at a vehicle just to see what they were equipped with coming out of the factory.
you can email them as well
[email protected]
Thank you for your gently replyYou can also contact GM with your VIN and ask for a build sheet they will gladly give you one that’s what I’ve done a few times before going to look at a vehicle just to see what they were equipped with coming out of the factory.
[email protected]
Thank you too
You're welcome! Plus, I wouldn't hate it if you posted your build sheet.Thank you very much again![]()
You are actually wrong on that. My bro has an 03 Tahoe z71 with 4.10s from the factory. Look at the glove box with the codes. If it says gt5 that means it has 4.10s. gt4 is 3.73.No lol, there aren't 4.10 ratio grears in it from the Factory. My 2001 has a Tow package and I it came with like 3.23's She has 4.10's now and man will she get up and go or pull a Boat or U-hual with ease. but the fuel Consumshion is Very Bad too. I belive there where two Gear Ratios that You could get from the Factory with the Tow Package.
waiting on ( The Hoe ) to Chime in or ( Jenn Bear )
