Dash question
johnheerhold
I have a 1995 Yukon GT that needs a new dash. It came with the dash with the cupholders but I would like to get the later one with the airbag. Will the one with the airbag fir without any fabrication?
exp500
Yes, I believe they all interchange. Grab the hole plugs from inst panel, you may need them.
96-2D-Hoe
I think the the dash without the passenger airbag is much nicer. But to each their own.
Ben Gatewood
Needless info.....Not sure about other years but my '95 2DOOR has 8 cupholders. A little overdesign? Just sayin...
east302
Mississippi
You’ll need the a/c duct if you’re going to a 97/98. Possibly the passenger firewall bracket as well...
I think there are two bolts under the airbag that connect the dash to it. Not 100% on that, so you might as well grab it and the bolts, just in case. You might not even have the firewall studs anyways.
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
I have a 95, swapped in a 97-99 dash. It was a direct fit. I also don't have the airbag on my new dash, it has a pocket instead.
Creek
I want to paint the dash in my 1997 Tahoe. According to the glove box label the GM Color code is 522. Does anyone know the correct SEM product number?
SEM doesn't correlate its colors with the GM colors or numbers. You can contact them directly -- and I would encourage you to do just that -- but they'll tell you that you need to get a custom mix, if you have a shop that does it in your area. I did a recent color comparison for mine and it wasn't all that great.
Creek
Thanks
TejasPitt
