Drok
Cold place in the north
Had to repaint the rear bowtie since its been on for a few years now. I decided to change it up a touch. Still have to smooth a spot or two out.
If I’m not mistaken, the fluid you are seeing is the fresh new stuff going in.
Dont think so, unless his diff has some magic amount of room over the top to pour fluid in, plus I see the pump in the jug.
Denaliz
Frisco,TX
Here’s my usb and hdmi ports plus my USB port running into my Dsp.
tbh/ Zero issues for me for a single usb. I run LDAC for wireless hi res, Apple car play,etc on my iPhone. Then I have a usb for my DAP player when needed. Keep in mind this is a pure SQ headunit from their excelon reference line. 2x USB’s pissed Me off at first and they have units with 2x if that’s your main need. Mine was the best sq head-unit with 5v preout, LDAC and large display.
the only thing that has held me back from getting one is the lack of usb ports or usb hub integration with the vehicle. 1 usb port is pretty sad for a $1000+ headunit, how hard is it to access the sd card slot?
28B844ED-2E77-42A2-B0A6-62D57E78A1F2.jpeg B03DA06D-2DB0-4D76-85A6-81EA05C7F838.jpeg
View attachment 269791 View attachment 269792
they have the 10" floating screen with 2 usb ports? which model
Jason in DLH
Cheeseburger and Fries
MN
Just Fishing
Can't fix stupid
Utah
Wife is trying to talk me into a Buick enclave for her.
Anyone know anything about em?
I'm looking at a slightly older one that my tech 2 will work with...
Maybe a 2011 or 12.
Googling around i'm not seeing anything about AFM, but some complaints about the cam phasers with the vvt (3.6l)...
Sparksalot
Bastrop County, Texas
Maybe a 2011 or 12.
Is it AWD? That will help with wheelspin versus the FWD version. I had an 07 then 08 Saturn Relay, loved them. Why two? You remember that washer fluid heater recall...
Maybe a 2011 or 12.
I've heard that the timing chains are weak and they commonly stretch and need replacing at really low mileages, like 20s-50s.
I have no personal experience with this other than helping a guy with a Camaro diagnose his.
bobsburban
Got done with the installation of a Tru-Cool 40k tranmission fluid cooler - it's a monster. Also plumbed in an ARB compressor in the front driver side battery tray since it was sitting empty. Air for tires no matter where I am now.
I'll try to remember to make some pix tomorrow in the daylight.
As promised - not much to see of the transmission cooler; the newer body work hides stuff far better than my 1995 Tahoe's but here's a couple of shots to give you a feel for how wide this thing is. That's the hood release lever in the foreground just for reference. I'm seeing transmission temps 35 - 50F lower than before on just my daily commute. Have a feeling I'll like towing a lot better now.
And, the shot of the dinky compressor that inflates tires like no tomorrow...
Just Fishing
Can't fix stupid
Utah
Engine out for that, lol
hopefully they updated the chain...
the_tool_man
Upstate South Carolina
The compressor idea is cool. I've been pondering what to use the spare battery tray for. Only problem is you have to carry a pretty long hose to reach the rears. Still cool, though.
Probably a dumb idea...has anyone attempted to use the Autoride air suspension system as a compressed air source? I read that it holds 80psi.
Bentley95
