Anyone try this big brake kit?
FrankU
Babylon New York
Look a bit further into a brake swap ? IF you get into an accident and the insurance company finds out that there are different brakes on the car other than original there is a very big chance that they won't cover you. Look further into it like I did.
Wilwood Baer etc. are racing brakes not intended for street use.
1BADI5
DMV
But the burden of proof or liability would have to be proven by the insurance company. This thought process would be like saying, you did not use the same OEM tires and wheels, therefore claim denied.
1BADI5
DMV
ZR1 calipers are not cheap right now, even used. Then factor in pads, hardware, brakelines, rotors ......its going to be a wash in savings once you figure in, shipping and taxes.
cfmistry
I added up all the parts... you end up around $1500-$1800 depending of the type of pads you get. Cheaper than the other BBKs but not by too much.
dougo
Raleigh
Have you tried the power stop Z36 kit yet i put them on my 06 i will use nothing else i tow a lot and need the extra stopping power save my ass more the once
91RS
GA
It is too expensive. I was going to buy them a while back but it’s still about $2k in parts all in and that’s IF you can find deals in the pads and rotors. I’d rather just buy the GM Brembo kit that is actually made for the vehicle and will go right on with no questions.
All that and you end up with calipers with Corvette on them. You won’t be far behind price wise to a Wilwood kit either.
calsdad
Ummm - I think that is incorrect.
The Wilwood big brake kits that they market for trucks - at least the ones for the 8 lug trucks - are specifically marketed for armored vehicles, vehicles that tow - etc. Go read the website.
Not sure why your insurance company is going to blanket not cover the vehicle - when you just made it brake better.
I can tell you for a fact that I'm much more able to avoid smashing into the rear end of people panic braking in rush hour traffic now with my 6500 pound 3/4 ton Yukon XL - than I was before with the factory brakes now that it has a set of the Wilwood brakes on the front.
FrankU
Babylon New York
This is what I found when researching a much needed brake upgrade. Don't get me wrong I want to put much more power in the Tahoe. Along with more power very much needed stopping power is also needed.
calsdad
You might be with the wrong insurance company. I don't recall any wording whatsoever in my insurance policy about vehicle modifications - and typically you'll on get dinged for a modification if it actually CAUSES an accident.
Again - bigger brakes that make the car actually more safe - shouldn't be the cause of an accident unless the wheel falls off after you make the mod - because somebody did something wrong.
Dh1280
