Looks really good. The shadowing looks blue, which doesn't look bad together.Snapped a pic with the DSLR, even though I forgot my polarizer.
237k miles
And my new paint damage from my hit and run in December. Thanks for that.
You check the fuse panel on the side of the dash too?
Should be one of the ones in the left side dash panel, you can test them all easily by just touching the tips with a meter
237k miles
TRY # 48 UNDER THE HOOD, (10 amp) It will say rear/aux hvac control but it also does instrument panel and mirror and heated steering wheelI checked every fuse in the dash fusebox... none of them were obviously blown (by inspection). I also noticed by CEL is not lighting up at all either, so clearly a cluster of lights isn't working in the gauge pod. Anyone??
But why did it blow?You rock! Turned out to be that fuse for those wondering / ever have this problem. It controls the instrument cluster and the temp/compass for the mirror... go figure! Was obviously blown and immediately corrected by issue.
Don’t do that. It causes grief.I was fidgeting with the wiring to my radar detector and I'm sure I manually shorted it out.
I’m an electrical engineer. I got to my station in life by making lots of sparks as a kid.Yes it turns out that touching live and grounded wires sparksalot... see what I did there![]()
You know, I’ve worked with a lot of electrical engineers, or sparkies as I like to call them, and I swear some of them were drunk when they went to the lab early in the morning and got shocked and shit got locked in the drunk config.I’m an electrical engineer. I got to my station in life by making lots of sparks as a kid.
LMAO!You know, I’ve worked with a lot of electrical engineers, or sparkies as I like to call them, and I swear some of them were drunk when they went to the lab early in the morning and got shocked and shit got locked in the drunk config.
I’ve only designed with that once. Service for a locomotive factory.25kv hurts....
