2007 Tahoe negative battery terminal
malvizar
Hi guys
I was wondering if anyone could tell me on the negative battery terminal, it splits into 2 wires, one going to to the block near the cylinder head and the other goes underneath towards the back of the radiator.
my question is why is that wire down there? Is just an extra grounding point on the chassis or is there something it actually goes to? The reason I’m asking is because I want upgrade my ground cables to 1/0 gauge.
Thanks
wjburken
Eastern Iowa
Hi guys
Thanks
Check out the attached starting at B-18. This might tell you what you’re looking for on the negative side of things. The other sections will help you on the positive side of things.
https://www.gmupfitter.com/files/media/photo/88/2007_LD_ElectricalUtilitiesSUV.pdf
wjburken
Eastern Iowa
cool I’ll give it a read. Thx
No problem. GM Upfitters is a good source of various information about these vehicles. Been using them since back in the day when they were actual hard copy books.
Dustin Jackson
Hi guys
Thanks
@malvizar The cable that goes down to the front of the Tahoe just bolts into the frame so it should be pretty easy to put together a new negative cable with 3 ends.
nath
Jasper Alabama
wjburken, Thanks so much for the link. just answered numerous questions I have had for my "old girl" for a long time. Thanks.
brice715
