2012 Yukon XL Denali 6.2L Cam Swap Thread
Geotrash
Geotrash
Dave
Richmond, VA
Love you guys - thanks for checking in. Got home from our 2,000 mile trip on Saturday and the old '07 with 211K on the clock did great hauling our camper. Sunday was unpack and clean, and this afternoon I'll finally get back into the project.
Geotrash
Geotrash
Dave
Richmond, VA
Alright gents, work has begun again. Oil pan is off, oil pump is off, no nicks or cuts noted with the O-ring for the pick up tube. Looks perfect, and I did install it correctly.
1BADI5
DMV
Do you have one of those pick up tube clamps? If not I will mail you one; I have a spare. It's great, cheap insurance.
Geotrash
Geotrash
Dave
Richmond, VA
I don’t! Thank you for the offer, but I’m going to have this thing buttoned up tomorrow I think. Out of curiosity though, what do they look like?
Geotrash
Geotrash
Dave
Richmond, VA
Got the driver’s side cylinder head off and found one bad lifter so far. It was the #5 exhaust. That also matches well with the cam lobe that was the most damaged. That said, to my eye, none of the other lifters look like the rollers are damaged at all.
Thoughts? I’m wondering if maybe a bit of grit got in there and stuck the roller. Either way though, the cam was definitely trashed. On most of the lobes in fact.
One more thing… When I installed the pick up tube into the new milling oil pump, the O-ring was a much more snug fit than the one I installed in the factory pump last time around. I’m wondering if even though I got the right red O-ring last time, if it was undersized.
Is that edge of the roller ground off, like it rubbed against the cam lobe or is it broken off, like the metal fractured?
Geotrash
Geotrash
Dave
Richmond, VA
It looks to my eye like a chunk came out of the metal, and then the roller got stuck and burnished the rest of it. The roller moves freely, so I suppose it could’ve been a chunk of debris in the roller bearing at some point, but hard to say.
Or a fracture in the roller that missed QC or was otherwise invisible. The roller fractures and the metal goes through the oil system, scarring the cam lobes, journals and bearings. The chunk of debris that stopped the roller from moving could've been a piece of the roller itself.
ls1frc
I highly doubt your oil pump was the reason for this. If you had good oil pressure, you were getting oil to where it needed to go. Looks like a defective part to me.
This is what I'm thinking. Maybe a flaw in the hardening process?
randeez
south florida
x2 ive ran engines with zero oil in them and not ended up that bad
Geotrash
Geotrash
Dave
Richmond, VA
Oil pressure was definitely lower than before the swap so something was off, but I agree, the engine was likely getting enough oil. No issues anywhere else but the cam lobes. Even the cam bearings were fine, and the cam was dripping with oil when I pulled it out.
Geotrash
Geotrash
Dave
Richmond, VA
Also, the Fel-Pro Perma torque MLS head gaskets looked like new when I pulled them out, but I used new ones anyway. Any opinions about reusing them?
thompsoj22
Yup, Ill second the opinion of soft/defective cam, Possibly the hardened rollers started destroying the soft cam material from the first startup. Shame how our perception of "quality" is based upon a small companys intent of putting out a good product but you might have an employee with a F'it attitude on a monday/friday and somthing like this happens. This project educated me, And when i do need to reman our engine i will only use OEM components. No hacking intended, It is simply getting so hard to find quality that is real as opposed to simply a verbiage marketing strategy.
Conedaddy
