Lowering kit
racerx
Looking to lower 2012 2” front and 3” rear.
I would like to use stock 17” wheels.
How much clearance issues should I expect with the front spindles?
Thanks in advance
Jason in DLH
Cheeseburger and Fries
MN
I’ll bump this for you. ;)
Sorry...not much help here as I opted to lift my rig. Hopefully someone with drop spindles here can help.
Thanks in advance
What clearance issues are you speaking of? Clearance between the spindle and wheel, between the wheel/tire and control arm(s)? Between the tire and fender or inner fender?
Kee Fuller
las vegas
Shouldn’t have any issues with a 2 inch drop up front. I don’t think you even need spindles honestly
R
racerx
between the wheel and ball joint nut
Read of people having to grind the nut for clearance
Ilikemtb999
Denver
I’ve got belltech knuckles up front, I had to cut the non threaded part off the lower ball joint. Also had to manipulate all 4 inner fender liners to not rub over uneven surfaces like driveways.
those are 17” steelies if it wasn’t apparent.
Ah. That's definitely a wheel diameter thing. If all it requires to run 17s is to cut the non-threaded part off the ball joint, as @Ilikemtb999 did, then that's nothing and harmless. I've seen on the 4WD that the stud of the upper ball joint has to be trimmed and a thinner nut used to clear the CV axle. Again- it's nothing and harmless.
Big Mama
Virginia
For example I left the longer bolt in the event I wanted to go back to stock height, which means my 17” spare won’t fit up front.
Ilikemtb999
Denver
At least I’m pretty sure I didn’t cut any thread, but now that you mention the thinner nut then maybe I did. I’ll go and snap a picture in a minute
You said you cut the lower ball joint so I assumed that was to clear the 17" wheel since that's all that would possibly interfere with a long stud on a lower ball joint. The stud of the upper ball joint would interfere with the CV joint. Hell, maybe you trimmed both and don't remember? lol
I've only had 20s or larger on mine so I wouldn't know. But, this prompts me to check into it in case I ever have a flat in the front cuz my spare is a 17" steely.
Ilikemtb999
Denver
Yea it’s been a few years, I don’t recall having any issue with doing it and riding on stock springs I think has its advantages.
tightchevelle69
Florida
also note if you have stick on weights inside the wheel. with stock 18's we had to trim the lower balljoint a good amount onto the threads to make sure it cleared the weights with an amount of space i was comfortable with. pic is with the stock 18's with 3" in the front and 4" in the rear.
CrashTestDummy
Pearland, Texas
We had to cut the ball joint stud AND install thinner nuts before the factory steel wheel would go on. I seem to remember there was a bit more clearance on one side vs. the other, but both had to get the trim and thinner nut.
tightchevelle69
Florida
I believe my spindles came with thinner nuts that we ended up using as well.
j_jerry79
