2015 LTZ Level Kit Question
Stanky
I’m looking at motofab level kits for my 2015 LTZ. I only want a front kit as I just want to even out the front with the rear height so I’m thinking a 2” will suffice.
My question is what is the difference between the two level kits in the screenshot below?
gat0r
DFW
the links @ bottom install on bottom of front strut
the round one @ top goes on top of strut
Stanky
Stanky
Makes sense. What’re the pros/cons? Is one easier to install over the other?
mb1500
The lowers are easer IMO. The upper has to have the strut pulled all the way out of the pocket to install. 6 bolts instead of 2.
Minor difference but when you look through the wheel well at the coil over the top spacer will be obvious to car guys while the lower allows the coil over to be in the original placement when looking at the pocket.
Stanky
Stanky
Gotcha, thanks. Glad I asked. The bottoms are cheaper as well.
FastLane1000
I am pulling both of lower 1.5" lift spacers and upper 2" lift spacers off mine this weekend and replacing with some RC lift struts. So I will these available for cheap if anyone wants them.
JasonW4141
