2012 Yukon XL Denali 6.2L Cam Swap Thread
Potential for problems is why I take so many pics and notes to document critical details. This helps in references for myself and with others performing the same work. It may also be helpful in a warranty concern should a supplier need to see how a part was installed.
Off the top of my head, I documented in pics and text my head torquing process, crank pulley installation, torque converter filling and installation, piston height measurements, push rod measuring and length, lifter comparison and measuring, timing gear alignments, timing chain comparison and measurements, oil pump shimming, mods to oiling system and rocker tip wipe pattern. I'm sure there are others.
Geotrash
Geotrash
Dave
Richmond, VA
Yes, I will do that in the teardown and reassembly this time as well. That's a good call, thank you for suggesting it.
I pulled the cam fully out and laid it on rags on the kitchen counter so I could get a good look at it under better light, and the damage was worse than I initially thought. Several of the lobes had significant surface scars and gouges. Again, the oil pressure was lower than before the swap but definitely not zero (hot idle was 15 psi indicated, highway speed it was 35), and the cam was soaked in oil when I pulled it out. Can't wait to get those lifters out to see if there's anything wrong with them. The damage to the cam looks as if the rollers were seizing up, but the cam bearings look great. Strange indeed.
thompsoj22
YIKES! I understand loyalty, It sounds like your supplier is going to the extent he should to remedy the problem, However, Somthing is completely f'ing fubar in your project and i would highly suspect the parts you used. Your asessment of the stock engine on teardown was "no discrepancy noted" it looked perfect! Your asessment on teardown of your project is "fubar"! IMO, remove every component you installed from divinci and choose a different manufacture. Remember your intent was to build reliability and longevity into your vehicle, Dont compromise your end results?
ls1frc
I'd have to agree with thompsoj22 here...
I went down a rabbit hole once with Lunati cams. Every cam they sent me made a horrible whining noise. So loud you could hear it over the radio inside the cabin and it was a very high frequency. They basically took no responsibility for it.
I posted about that on the forums, I think it was like 2013. Cam Motion replied to it and said it was probably the finish on the cam lobes. He sent me a cam for FREE and it fixed the problem, dead quiet. They earned a customer for life. Every single cam I have purchased after that has been cam motion.
Cam Motion also cam doctors every cam that goes out, so you know the specs are what they're supposed to be.
Since you're doing the 3 bolt, order one up and get their 8620 core. I ran that alloy in my G8 for 40k daily driven miles, still looks brand new.
Geotrash
Geotrash
Dave
Richmond, VA
Okay, I'm getting more and more convinced to use a different cam. Two questions:
  1. Do you think I should keep the Vinci dual springs? They're beautiful but I wonder if the pressure they require could be part of the problem.
  2. Cam Motion makes a cam specific to the 6.2 rectangular port engines, but it's not in stock anywhere - estimated delivery 1/4. Should I wait for it or go with the Summit that has slightly milder specs (fits 6.2 but not 6.2 specific) that's available now.
Thanks for your thoughts.
Option 1: https://www.summitracing.com/parts/cxm-03-08-0031
Option 2: https://www.summitracing.com/parts/sum-8712
Vinci dual spring specs:
155 lbs @ 1.780"
360 lbs @ 1.230"
380 lbs @ 1.180"
400 lbs @ 1.130 "
coil bind @ 1.070"
od; 1.300
ls1frc
Those cams are not ideal for your setup they are .500 lift. Now you could go that route if you just wanna run stock springs. I had to wait 4 weeks for my cam as well, everything is backed up right now.
Your springs are overkill for any cam under .600 lift, that's for certain. Though with good lifters, they should be ok.
You can contact BTR, I believe they use Cam Motion as their cam grinder now.
Geotrash
Geotrash
Dave
Richmond, VA
Excellent. Thanks again for the help - gonna owe you a bottle of scotch even if you don't make a tutorial :)
Think I'm gonna go with the Brian Tooley Stage 2 truck cam.
Specs: 212/218 .553/.553 111+0
https://briantooleyracing.com/btr-camshaft-gen-3-4-truck-stage-2-v2-btr31218110.html
Spoke to them on the phone and confirmed that Cam Motion is likely the supplier but it's made to BTR specs. Going to go with BTR beehive springs and standard valve stem seals. I'll verify preload this time and will order standard length BTR pushrods as well.
They confirmed they have everything in stock and that it should arrive by Monday. That means I can get this wrapped up over the holidays, too.
Geotrash
Geotrash
Dave
Richmond, VA
Thank you, John. Your post is part of what tipped me over the edge to going a different route.
ls1frc
Yeah can't really go wrong with that setup + the morel lifters. It's a a set it and forget setup. My 5.3 used the stage 1 version, it ran well and was quiet.
Happy to assist.
I serviced the overhead doors for their shop years ago and had a nice convo with the owner. Verifying perfection was one thing he harped about. Had I not gotten the friend deal on my TSP cam, I definitely would've bought from them.
Geotrash
Geotrash
Dave
Richmond, VA
All of the new parts have arrived. Gonna tear into it this evening and tomorrow and see how much I can get done. Not looking forward to dropping that oil pan again, but se la vie. Intake manifold is already off. Hopefully it will all go much faster this time.
thompsoj22
Thanks for checking in! Made good progress over the weekend but still don’t have the heads off yet. Decided to leave and go camping for the week with our ‘07 Denali.
Great choice! Thanks for using the forum to document your challenges as it without a doubt will help other forum users to make decisions. And your end result of longevity and reliabilty will give you confidence when the vehicle is still pulling strong at 200k miles!
randeez
south florida
Don't feel bad...started working on mine like 3 years ago and still not done
MonteJ
