2021 Yukon SLT Black Out Process
TwoFeet020
Hi Guys, first post on this forum. First Yukon I Own as well. Couldn't be happier with it!
Wanted to share some photos of disassembly of the grille to have pieces painted black. Took me about 4 hours to take off all the pieces. The tabs on the grille took the longest, almost 2 hours just sitting there removing tabs carefully!
Does anyone also have any insight how to remove the rear chrome appliqué circled in red? Was thinking the painted appliqué, circled in blue, has to be removed (not sure how? just nuts and clips interior fo lift gate?)
TwoFeet020
TwoFeet020
Well i took a stab at it and figured it out. Liftgate has two moldings on the side to pry off, remove nuts from appliqué backside and two yellow type of push pins from inside the liftgate that can be squeezed to loosen the retention followed by pulling off. All done. Will post photos of completed black out soon.
91RS
GA
Are you replacing with AT4 pieces?
91RS
GA
Definitely does look better. Are they thinking it's going to last? Painting over chrome has never held up for me in the past so I've resorted to buying factory black parts or just leaving the chrome.
TwoFeet020
TwoFeet020
You have a great point. They believe it will however experience has shown me rock chips from daily driving take their toll. As time goes on I’ll reassess. Either repaint or buy the factory black parts.
Stbentoak
You could also Xpel film over it in applicable places and that would protect it also...
It's sharp and worth the effort. It takes this vehicle from Meh to "Wow, I've never seen one like that before !"
Elarson6772
View attachment 264939 View attachment 264941 View attachment 264942 View attachment 264943 View attachment 264940
So....any links or info on how to remove the front grill and headlamps?
B520044
I'd like to add the AT4 fascia onto my SLT, but looking at your pics I don't see tow hook mounting points.
crazycrew
Vacherie, LA
Nice! I did this with my last truck (2017 Sierra) to have the grille pieces painted. I used and old CC that I cut up to wedge between as I popped the clip from the grille to hold it open. Used a piece at each clip placement. Made it 10x easier.
R32driver
About a year later now so how are those painted pieces holding up? Did you do the rest of the trim? What about the door handles? I'm looking into options on our slt to change up the chrome trim. I'd like a lot of it painted body color but worried about how it will hold up long term.
Candielaine
