Jason in DLH
Cheeseburger and Fries
So I’m a bit confused as this is the first time using a scan tool to cycle the ABS system. A few questions:
1. I read somewhere to do a complete bleed on all 4 wheels prior to performing ABS bleed. This true?
2. I did a complete bleed last night using a Capri Tools Vacuum bleeder. Do I need to basically do a whole round of bleeding on all 4 corners with the ABS cycling now? Or just perhaps on the right rear (furthest from master cylinder)?
3. How long should an ABS bleed take roughly?
I’d rather take the whole ABS system out or offline as I like to lock the tires and manually remove pressure from the pedal to regain steering ability. ABS stinks on snowy, hilly roads! My old Jeep had no ABS and manually using the brakes works way better! Anyway I can do this easily? Perhaps simply pull a fuse?
Thanks in advance!
Thanks in advance!
