Did you watch it? Did you hear the pop? Seemed to me that may be like the popping you were describing..?It's just running at idle?
Ahh, I didn't notice. I'll look again.Did you watch it? Did you hear the pop? Seemed to me that may be like the popping you were describing..?
I do hear it now. Does sound familiar. I noticed mine through the exhaust, I don't think I hear it from under the hood.Did you watch it? Did you hear the pop? Seemed to me that may be like the popping you were describing..?
Maybe you can try with the hood open, and see if it’s similar..?I do hear it now. Does sound familiar. I noticed mine through the exhaust, I don't think I hear it from under the hood.
Thx for the heads up. I just hope it doesn't hurt the motor in any way.
I will.Maybe you can try with the hood open, and see if it’s similar..?
Between the guy's motor and mine?What makes the crank relearn necessary? I've never had to do one and have replaced several crank sensors/entirely different engines with different cranks lol.
Well, pitter patter, let’s get atter!I'm all set.View attachment 264293
Gonna do it tomorrow--hopefully.Well, pitter patter, let’s get atter!
I took it for some local errands and local highway driving. It drives like shit. Still popping through the exhaust and it almost sounds like every once in awhile it backfires. Nothing loud--maybe like a misfire. It idles fine--still hear a popping coming from exhaust. No codes either.
Nope.Well that's not kosher.![]()
I do. I'm willing to give it a shot.What do you have to lose by trying the crank sensor relearn? You have a Tech 2, correct?
If it needed a crank relearn would it show a code of some kind?What do you have to lose by trying the crank sensor relearn? You have a Tech 2, correct?
IMO, you need to get it tuned sooner rather than later. Try the crank re-learn or whatever but get it tuned. Also, have you put some octane boost or run enough premium through it to go out of low octane mode?
Am I looking at lt or st? Should it be at 0 while accelerating?yea needs to be tuned...you can prob ride around and watch the fuel trims, they prob way off under acceleration
