Tire monitor delete? Anyone?
Maybe that guy who customizes BCMs can do it. I've grown to like it; can now get the tires to within 1/2 psi of each other and the truck runs so much smoother when they are all the same pressure.
Nrphlly
Nrphlly
I am running big wheels, I’ll definitely notice if I’m down on pressure at any point.
Nrphlly
Nrphlly
You can't delete it with a Tech2, but you can adjust the pressure they're set at to give the warning
They swapped out my wheels and didn’t put the monitors back on the truck. So I have a permanent light lol.
They’re easy to install, just have to break the beads.
And that's easy to do at home, too.
akbrener
Baltimore, MD
grab the 4 sensors and throw them in a PVC tube thats capped with a valve stem, pump it up to 36 and throw it under the back seat.
Have you actually done this? I tried but couldn’t get them to program. Maybe it was because they were new- I heard something about them needing to be “woke up” by installing them and the tire needs to spin at something like 25 mph.
akbrener
Baltimore, MD
I havent personally, but know a few people who ran like this. worth a shot right?
St. Louis
Doesn't work, well, it will at first but then they go to sleep and need to be woken up by moving (or spinning in a tire) and the light will come back.
I believe member @Jolly Roger tried different things about a year ago and has a big post about it titled "Wires sticking out of my tires".
Ultimately, he used that spoofer box linked to earlier above.
dizhai
