Nrphlly
- Joined
- Sep 3, 2020
- Posts
- 42
- Reaction score
- 51
Can we delete this feature? It’s completely useless for me
The AutoSync from BTdieselworks can turn it off and do a whole lot of other cool things to boot...
https://www.btdieselworks.com/collections/autosync/products/autosync
You can't delete it with a Tech2, but you can adjust the pressure they're set at to give the warning
They’re easy to install, just have to break the beads.They swapped out my wheels and didn’t put the monitors back on the truck. So I have a permanent light lol.
I remember that trick. Pretty cool.And that's easy to do at home, too.
Boss!!!!And that's easy to do at home, too.
Have you actually done this? I tried but couldn’t get them to program. Maybe it was because they were new- I heard something about them needing to be “woke up” by installing them and the tire needs to spin at something like 25 mph.grab the 4 sensors and throw them in a PVC tube thats capped with a valve stem, pump it up to 36 and throw it under the back seat.
Doesn't work, well, it will at first but then they go to sleep and need to be woken up by moving (or spinning in a tire) and the light will come back.grab the 4 sensors and throw them in a PVC tube thats capped with a valve stem, pump it up to 36 and throw it under the back seat.
How do you get the bead to seat again? Starter fluid like the stretched tire kids lol?And that's easy to do at home, too.
