Front end. Need to rebuild the front end.
lee.solorzano
Need thee whole front redone upper and lower control arms. Wheel bearings. And everything else. Trying to ge a whole kit. Besides Amazon or eBay. Any idea.
wjburken
Eastern Iowa
RockAuto is a good source for parts. If you go with them, make sure to find their discount code in their vendor thread on here.
GMpartsdirect is another place people have used here.
Geotrash
Dave
Richmond, VA
I used all Moog parts when I redid mine a couple of years ago. Similar to others, Moog has several different lines, so I only used the top of the line stuff. So far, it's all holding up great and still rides like a new truck.
There are kits available on eBay cheap, but they're no good. Get quality OEM or Moog parts for the front ends on these things.
Dave
lee.solorzano
lee.solorzano
Dave
I will
Stay away from the kits. I prefer GM OE or OE suppliers, like Timken for the hubs.
Front Hubs - Timken - SP500301 (4x4)
Here's my list of Upper and Lower Control Arms for my truck, don't know which 900 you have, last updated about a month ago:
Dustin Jackson
@lee.solorzano I used the top of the line Moog stuff, it can all be found on Amazon. If you are unsure on if you are getting the right part go to their website to make sure you are buying the premium line and not the economy line.
Amazon sucks ASS at shipping the lower control arms, the box came destroyed but luckily the lower control arm is a heavy duty part and wasn't damaged.
lee.solorzano
lee.solorzano
U get them through. Amazon but I’m getting lower spring and spindle and get all new center link and pit arm and idler arM and rod ends
lamerem
I rebuilt mine last weekend..
I used MOOG (CK level parts with problem solver components).
Replaced:
  • Upper and lower control arms (do yourself a favor, purchase new bolts from GM that mount the arms to the frame. This was a life saver!)
  • Inner and outer tie rods
  • Sway bar links and bar bushings
  • Rear upper control arms
  • Rear lower control arms
  • Rear panhard bar
Bought the majority on Amazon, and the control arms at my local Advance auto for ease of warranty if anything should happen.
lee.solorzano
lee.solorzano
Replaced:
  • Rear panhard bar
Thanks will do
lee.solorzano
lee.solorzano
Can any one by looking at the lower control arms tell if I have the steel or aluminum one please. I want to replace everything thing
CKendrick
