02 Tahoe cruise control cable retainer c clip
Livebai8
Houston, Texas
Yep...i lost this sucker when I removed my intake and throttle body and replaced my shock sensors.
Any idea what size c clip I need to replace and lock the retainer bacl onto the throttle body?f751637a508d04a3401b89ab24d1f18b.jpg
02 TAHOE LS 4X4
5.3l FLEX FUEL
285/70/17 W/Z71 RIMS
Sent from my SAMSUNG NOTE 5 using Tapatalk
Livebai8
Livebai8
Houston, Texas
02 TAHOE LS 4X4
5.3l FLEX FUEL
Anyone?
02 TAHOE LS 4X4
5.3l FLEX FUEL
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
The c-clip is not serviceable, comes with the retainer pictured.
GM#12479921 $12.00
S33k3r
Dallas, Texas
If you don't get an answer here, you might check one of the build threads to see if anyone has made any changes in this area. Likely they'll have the specialized knowledge you are seeking. On the flip side, have you tried any of your local boneyards?
Livebai8
Livebai8
Houston, Texas
GM#12479921 $12.00
Oh ok. How exactly do you take it off to replace it?
I don think I’ve ever seen it done except for a video where i saw another person pop it out of there on a s10 pick up. I thought maybe there were all held on the same way??
taylorb71
Central North Dakota
What I did was cut the end off, slide a stock style one on the wire and put on a throttle cable stop. I used what I had. The retainer I had didn't have the slot to put the cable up in just a hole going through the middle.
Leno1364
