Have Dyno numbers for you!!
COTahoeLS
Senior Member
Colorado Springs, CO
Had a free Dyno Day today put on by some friends of mine that built my Evo prior to my serious accident last June.
Anyhow, I was peer pressured into throwing the Tahoe on the dyno to see what she does before I order my charger from Black Bear this summer.
It is a DynoComp Dyno that is known throughout Colorado as being the HeartBreaker because no one likes to dyno on it and see their real numbers.
Keep this in mind.
She has an AirRaid intake tube, KN panel filter, 90K mile spark plugs and wires (changing on Monday), 91 octane and a BB tune for 91 octane. I am also at 6300 feet elevation (thin as hell air).
She pulled 213.9whp (in 2wd mode) and 239.4 wtq. A lot of the guys were impressed.
To compare to another dyno in the area. A buddy of mine pulled 504whp in his Evo last week at another dyno and today's dyno showed 414whp for the same car.
What do you think?
-Erich
Edit: Correction factor was 1.12
AquinoSteven
Key and Spacer Guru
Clinton, NJ
Seems about right. Im guessing 320hp at the crank and idk 30% drivetrain loss is 220whp. 96hp is lost through the trans.
Justin
Pretty good numbers there Erich, considering the altitude. You'd have 20% more power at sea level.
Justin
Jeeze, well my stock 5.3 made 270whp/290wtq in 90degree heat last summer on a dyno jet.
On any other dyno it probably would have been closer to 245hp. DynoJets are good for comparing to DynoJets only due to their inflation factor.
Fast55
Ventura County USA
Those numbers = OUCH! I don't suppose you have pre and post tune numbers for a 6.2? If I ever get the damned transmission working right, I will be getting a programmer/tune. I was hoping for well over 300 RWHP stock, and hopefully, at least 20-30 RWHP gain after tuning? Any special instructions to the dyno guy to do this? I'm guessing traction control off and trans in manual running up in 4th gear?
Justin
Colorado Springs is around 5000' elevation which has 80% of the air density that you have at sea level, that's 20% off right there.
In addition, TRUE rwhp is always lower than what people assume they get when comparing to DynoJet numbers. This dyno he used reports actual power output, not the 18-20% inflated number of a DJ.
Unless your 6.2L is a 2wd, which most are not, you'll have a very tough time dynoing it. Transmission gear doesn't matter either aside from overloading the dyno via the torque multiplication there is no such thing as a 1:1 ratio with the 6L80E. 300+ at the wheels with any dyno shouldn't be a problem. The 2007+ 6.0L trucks regularly put out 295-300rwhp after tuning.
Fast55
Ventura County USA
I realize that altitude makes a huge difference, that's why I was expecting 300+ RWHP from my 6.2 even stock (I'm at sea level). My truck is a 4X4 LTZ that has 2WD available unlike an Escalade, so I wasn't expecting any issue with dyno'ing it even stock? I was under the impression that 4th gear was 1:1 and only 5th and 6th were overdrive gears?
Justin
There is no 1:1 gear on the 6L80E, but that doesn't matter much anyway as there is still multiplication going on via the differential and the ratio of the tire diameter to roller diameter. You should have no problems with your 2wd tahoe, other than the fact that the stock tune won't run to nearly high enough of an RPM to make peak power, manual mode is overridden at the low speed of 5200rpm in 3rd gear and above.
1st Gear Ratio 4.027
2nd Gear Ratio 2.364
3rd Gear Ratio 1.532
4th Gear Ratio 1.152
5th Gear Ratio 0.852
6th Gear Ratio 0.667
Reverse 3.064
COTahoeLS
COTahoeLS
Senior Member
Colorado Springs is 6300' elevation.
5.3L Flex but was using 91octane with 90K mile old wires/plugs (which I changed today destroying the old wires).
---------- Post added at 10:19 PM ---------- Previous post was at 10:17 PM ----------
Justin-
Do you want me to send you a copy of the dyno sheet scanned via email? I won't post it here.
-E
Justin
Justin-
-E
Sure, feel free to email to [email protected]
Fast55
Ventura County USA
Reverse 3.064
Ok, so leave it in 2WD high, traction control off, and run it in third, or up to the 99 mph cutoff in 4th? If I buy the programmer from you is it possible to leave it stock and get rid of the limiter to get a good baseline before I do a scan and send it for you to tune? I have no doubt I'll be impreseed with the results, I'd just like to get real before and after numbers if possible.
Justin
Yes, that wouldn't be a problem to bump up that tap up/tap down shift point.
These newer vehicles really seem to dyno well, despite the often lackluster performance on the street, so it should do well for you.
Fast55
Ventura County USA
Ok, I think I'm going to go with what I have for transmission operation. I've now had it to another dealer and they bless how it's working after the latest software flash although it still occassionally "flares" or seems to momentarily almost hit neutral on the 2-3 shift at very light throttle, especially when not fully up to temp. It seems Ok if I'm deeper into the gas. I will need the programmer and cable or whatever, and then I get a dump that is sent to you for a "custom" tune based on this info? Do I call you or someone else with shipping/payment info? Let me know, I'm done waiting on the cheaper handheld (autocal?) solution.
varminpoolteam
