Best hose clamps to get.
bigrhino
l.e.s manhattan,nyc
I have a Airraid jr. installed on my Tahoe. At times the air intake comes loose. What can I do to solve this problem?
Derick
Indy Suburbs
Safety wire. I had similar happenings on my kawasaki concours....leaked coolant just 2 years after replacing all the rubber and the clamps. I bought SS clamps, and because there was no corrosion to help "lock it in" they back out. If you get some safety wire, you can secure the worm screw with it.
exp500
Breeze makes some good ones, the constant torque might be worth the expense here, or even just the liner type. Safety wire is a good tip also if clamp is loosening. Thanks Derick for the reminder.
Bandit-66
Dierk,
whats the diff on the W1, W2, W4, W5 in asst. Is it sizes, bc it really doesnt say much
these are the material specifications and the sizes are in mm, not in inches
W1 completely made of galvanized steel
W2 Band and housing made of stainless steel 1.4016 Screw: galvanized steel
W4 Band, housing and screw made of stainless steel 1.4301 or equivalent corrosion-resistant steel
W5 made entirely of stainless steel 1.4401, 1.4436 or 1.4571
Monz11
Da Burg, Fl
are you familiar with their assortment lineup??
Monz11
Da Burg, Fl
do you have experience with their assortment line?
Bandit-66
yes, as already mentioned in my first thread, i use the clamps very often. actually only for all connections.
They are very stable, because of the rounded edges, they don't cut into the rubber and don't start to rust.
I used Roadformer t-bolt clamps, they're like the ones linked here but fairly inexpensive, from Amazon, for my CAI. I like spring clamps for the smaller sizes. There is an option to find what they call "constant tension" t-bolt clamps too that incorporate springs on the t-bolt. I know Mishimoto makes some but they're expensive.
https://www.amazon.com/gp/product/B07M8BCFD1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/dp/B00ED8SWN...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Durobans
