2005 gmc denali amp lux and woofer .
Woodblocker55
What radios does it work in ? I have a 2006 gmc yukon xl 6 changer head unit no nav ..
Would it hook in ? Where can I learn about it's wiring ?
Sent from my LGL722DL using Tapatalk
Thanks for the vote of confidence Joe but I'm no expert in this area. I would reach out to Mark @Rocket Man, Wes @Doubeleive and some others that have experience with the 800s and their music systems.
I don't know myself you might have to do some googling with the part number and see if you can find a compatibility list, sometimes lkq or a junkyard can tell you what it crosses over to.
At first glance, I wouldn't see why not, they are both 800s and the last flight, those two years are identical, if not near so. Joe Yukon, you can pick up the shop manual and wiring schematics for about $20 on ebay, as a disc or download.
bigdog9191999
sw michigan
so your looking to put a factory nav unit in a truck that did not have it? trying to be sure before I step into something I may or not know.
If you’re asking about adding a lux amp and the associated Bose sub into a non-lux vehicle afaik it’s not possible. I have the lux amp in my 02 Denali but I’m running a Pioneer HU, and the sub output goes from that to a separate mono amp and a JL 10” sub in an MTX Thunderform enclosure. The lux amp drives the 8 satellite speakers which are all aftermarket. But mine came with the lux amp. The wiring harnesses between lux and non lux vehicles are completely different. If you’re asking something else, please elaborate.
Woodblocker55
Woodblocker55
I found a website shows what wires to change . To convert non lux rig to lux ..I will post it later . I'm working on getting lux head unit out of the 2005 Denali . It's the am fm cd cassette unit 6 CD changer in middle. I confirmed it was lux . Not the nav head unit . I will post my findings . I have a pdf of wire change . Wonder if this radio has xm radio also..
Woodblocker55
Woodblocker55
Does a 2005 denali have a front center speaker on the dash ? I think it's showing one more speaker .I'm still digging thru details . I'm going to pickup head unit next week..
adventurenali92
Big Bear Lake, ca
I’ve never seen a GMT800 truck with a speaker mounted in the dash. My 2006 Denali does not have a center dash mounted dash speaker either.
Woodblocker55
Woodblocker55
Thanks .. Its all part of figuring out there wiring .. my 2006 Yukon XL has 8 speakers and a sub front center console .. I have read lux or non lux all had were the same speakers . But there wiring is head scratch . I might have set up a bench test .
adventurenali92
Big Bear Lake, ca
Yeah my Denali with the lux package has the same 8 speakers plus the sub under my front console.
Lol
I like how they call the d pillar speakers “twiddlers”. Back there just twiddling around.
Woodblocker55
Woodblocker55
Lol
I have like 5 diagrams to figure out .. once I get head unit it might all make more sense.
I would be more inclined to go aftermarket. The only reason I left my lux amp in was because of less wiring. I like my wireless CarPlay/ Android Auto with touch screen and have no use for the CD changer so I removed it. The hybrid system I ended up with sounds great.
Woodblocker55
Woodblocker55
Yes I understand that I'm a kenwood fan . I was just kinda surprised it can be done with lux to Yukon XL . And if I have everything I would try it .. yes I like my HD DAT player in LG V10 . HD audio is amazing . I kinda like everything .. I have a non bose 7.1 speakers in 2002 Cadillac deville with CD player stock total of 8 speakers counting sub. When it plays CDs it sounds better then my HD audio tracks it's a amazing stereo in the caddy .. I don't know why it just is better then others.. And I'm wondering if that lux does the same thing in denalis and escalades . Because that's one amazing stereo in that 2002 Cadillac deville it's actually a livery W20
It stereo is a notch better than others. It's got about 8 inch sub on back deck came stock but it doesn't say Bose anywhere only numbers . W20 was Cadillac professional grade. Has the rear vanity lights for hauling around the elite. So who knows what kind of stereos in there but I know it came stock. It sounds dam amazing . My comparing ear alpine polk boston acoustics pioneer kenwood Yamaha I tried a bunch different stereos thru the years . Maybe lux holds the same kinda amp as in the professional caddy it's only a hunch.
W20 was $4500 option in Cadillac deville livery. Cc Crazy.
I have noticed mine has great imagery, almost like 3D surround sound. But that’s a hybrid with an aftermarket HU so I can better control the input so it’s the best of both systems. Are you considering just the lux amp with aftermarket HU? I thought you were talking the factory HU.
Woodblocker55
Woodblocker55
I want factory first just to see how it sounds and works with stock am fm cd 6 changer . And after that try after market head unit on that amp. It take while to get there . I'm still working on tranny lines and brakes lol. I'm going to get stock head unit Monday .
DougAMiller
Colorado
You definitely can put a LUX system in a non-LUX vehicle, but as you are finding it does require some rewiring. It is not plug-and-play. I've done it, and I think the sound improvement is worth it. It looks like you have the amplifier wiring modifications, but to get the full benefit, you will need to run 4 new wires from the amp to the driver's kick panel. The rear door speakers and the D-pillar speakers are tied together at a connector there on non-LUX systems. To do it properly you will need the correct terminals to separate the wires and put the D-pillar speakers in their own cavities and connect the new wires to them. To really do it right, you will need terminals for the console harness connector under the cup holders. If you don't run the new speaker wires through that connector, you will have these speaker wires preventing you from removing the console.
Then, the amplifier needs to be configured to your cabin type (standard, XL or EXT, or if it's a Denali LUX amp it could even be configured for a standard pickup cabin). If you know what it came out of, it may already be configured for your cabin, but if it is not or you don't know what the donor vehicle was, then you'll need a Tech2 or a trip to the dealer to set it up properly. In my case, the D-pillar speakers had no output after I separated the wires until I programmed it for a standard cabin Escalade.
Woodblocker55
Woodblocker55
Thanks for the post.. yes it's going from 2005 denali xl to 2006 gmc Yukon xl .. I was able to get all connectors cut out 8 inches long . So I can see how it was wired from. Council also . It's out of same rig so there both Yukon xls .. I sure I will need some extra speaker wires as it's bit head scratch . I need to get XM unit also does that unlock with radio ? Using tech 2 ? Witch speakers are the D-pillar ones in very back ?
Eickybobby5050
