Remote start
Jaggar Siever
Hey guys a just bought a 2008 chevy tahoe and it has remote start but every time I go through the sequence I will hit the lock button then hit the start button the lights will flash and then the lift gate will open. Has anyone had this happen and it it a program issue
PG01
Up here to the right
Not to be a dick but you sure you’re hitting the correct button? It’s the top one
Next thing I would do is take remote apart and makes sure contacts are clean, fresh battery and that the contact board is inserted correctly.
J
Jaggar Siever
Not to be a dick but you sure you’re hitting the correct button? It’s the top oneView attachment 258727Next thing I would do is take remote apart and makes sure contacts are clean, fresh battery and that the contact board is inserted correctly.
No problem and yes i hit the lock button twice and then the start and it opens the lift gate. Both of my remotes do it and iv put new batteries in both as well
wjburken
Eastern Iowa
What happens if you just hit the start button? Does your liftgate open as well?
What about if you hit your liftgate button? Does that also open your liftgate?
J
Jaggar Siever
If i just hit the start it will open the lift gate and if i hit the liftgate it will open it as well
You think both of them?
no then probably not, if you don't have a tech2 then I would try taking it to the dealer and have them re-program the fobs, maybe the programming got screwed up or "somehow" someone managed to program them that way. if reprogramming doesn't work then it may be a bad the module on the truck, if that turns out to be the case I would try and find a used one from the junkyard or online like ebay, dealer is probably going to want a grip for new module.
petethepug
Michael
SoCal
That’s pretty funny!!! It’s an 08 so ordering a new remote off Amazon is less than $10. 2008 also means the key AND the fob can be programmed via the trucks own system.
When the new key is programmed, the others are wiped unusable unless they’re reprogrammed (again) at the driver speedo console or DIC (HA!!)
nath
Jasper Alabama
Jagger did you figure it out? I have had an 2007 for 8 or 9 years now and gave up on the remote start. But Im gonna call the dealer tomorow and see if they can make mine work and for how much. I friend told me on his 09 he had to go to dealer and the charged him 150 dollars for new fob and program to remote start.
Walkman
I have the same problem on 07 Tahoe LTZ, there are no codes and I have tried two sets of aftermarket Key FOB, and the two working original factory Key FOBs, changed batteries, reprogrammed the Key Fobs, they all do the same exact thing as jaggar said. There no open door, hood, or lift gate indication. My On-Star subscription shows no codes or faults whatsoever, my little ODB/ODBII reader shows no codes at all, all senors working normally. I wonder, there might be a sensor, which is not shown DIC but monitored by the remote start?
Fubar0715
Scott
Southern New Hampshire
Slight off topic question - when reprograming FOBS on 2013s - must you delete all existing prior to programing a new one using the Tech2?
Anytime you program fobs regardless of model year you need to do all of them at once. The prior code no longer works so the existing ones will no longer work unless they’re programmed at the same time as the new one (s).
Fubar0715
Scott
Gotcha - explains why I couldnt program just one. I was afraid I would loose my existing working FOB if I cleared all the from the system.
Drewphil
