Steering problems
J Farris
Lately my steering has been very loose like if the front end is swaying and today there is a vibration in the front I dont even know where to start
Did the looseness and vibration begin at the same time?
Loose lug nuts, severely worn hub, severely worn ball joint(s), worn tie rod(s) or separated belt in tire can cause both.
Broken sway bar end link, worn control arm bushings, worn shocks and worn steering bushing(s) can cause looseness.
Wheel out of balance can cause vibration.
J Farris
J Farris
Looseness started 2 days ago and vibration started today
Stimpy911
I just had my 2006 Yukon XL Denali in because of the drifting. The shop told me I needed to replace my pitman arm and idler arm. I still have to make the appointment.
Sent from my moto g(7) supra using Tapatalk
Vibes all the time?
At and/or above certain speeds?
After hitting a bump?
What are the specifics of your ride- 2WD or 4WD/AWD, 1500 or 2500...?
Lowered?
Lifted?
J Farris
J Farris
Thats what im thinking it is always gotta spend some money
J Farris
J Farris
Vibes all the time?
Lowered?
Lifted?
The front vibrates at higher speeds
2WD 1500 stock height
GMT800 SUV/Trucks
Military
@iamdub has given you a great list of possibilities that need inspected. Do you have the know how and capability to check them?
The vibes at higher speeds sounds like wheel balance, like maybe a weight or two has come off but that should not give a loose front end feel.
J Farris
J Farris
A 2WD 1500 would have rack-and-pinion steering, so no idler or pitman arms. Have you jacked up the front to perform any preliminary checks?
I haven’t checked anything yet
losloho02
