George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Not on my '07 but on my older 89/91 Burbs it was a necessity. For the '91 I actually got some plexiglass from Home Depot and made a shield that screwed onto the grille instead of using carboard and bungee cords.
GOD I MISS MY OLD GIRLS... :(:(
View attachment 258403 View attachment 258404
Did your heater core return hose go to the radiator? If so it's no wonder. When routed like that it bypassed the thermostat. Had a radiator on Ol' Butterscotch that was plumbed that way and it was a cold pig in the winter. Moved it to the port on the water pump and she worked great down to -20 without covering the grill.
kbuskill
NE. FL.
No. I used the factory camera with the head unit.
My factory backup camera didn't have backup lines but the Kenwood backup lines still worked.
My new Kenwood CMOS-320 multi angle backup camera has the option to use the cameras backup lines or not.
I chose not to because I like the lines that turn with the wheel.
kbuskill
NE. FL.
Just to add to my above post, I used an OBD2 splitter like this and mounted it under the dash so you can't see anything aftermarket showing...
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I don't recall it having a port on the pump for a heater hose just the intake hose from the radiator to the pump. I believe it came out of the back of the manifold into the heater core then to the radiator. And the pipe coming out of the manifold were known to rust out and take a shit.
kbuskill
NE. FL.
The pac system doesn’t have an obd2 plug. Idatalink does? Confused on how you plugged it into the obd2 to get the lines to move.
Yeah, I guess maybe it is on the Maestro. I couldn't remember if it was on the radio or the Maestro. So I guess yours doesn't?
Denali2k8
Anyone have a pic of the guts of the amp from a 2008 Yukon Denali? Bose amp...
kbuskill
NE. FL.
Anyone have a pic of the guys of the amp from a 2008 Yukon Denali? Bose amp...
Not 100% sure what your asking for but there are two different Bose amps.
I would assume your Bose amp would be the "smart" Luxury amp, and not the "dumb" Premium amp, since you have a Denali.
CaptainAmerica1
Arlington TX
My 90 was stolen out of the apartment parking lot back in January...
PG01
Up here to the right
Anyone have a how to remove the console? I got a usb wire and want to put it inside the console.
Pull the cup holder.... entire tray comes up, no screws there. Then there are screws inside under the armrest but just pulling the cup holder/tray assembly will get you 95% of what you want to do
Escalade2007
