Something Rolling Behind the Dash
seabas22
Driving the 2019 Tahoe (22K miles) yesterday and sounded like something broke lose all the sudden and hear something rolling around behind the dash on passenger side. I was driving maybe 35mph on smooth straight road, not like I hit a bump or curve or anything. It's not anything in the glove box or storage compartments. Any ideas?
Let us know what you see, after you have removed the glove box and inspected the area.
Tahoe14
Central Fl
I believe there is a youtube on how to remove the dash pad if you need to go that far.
S
seabas22
Removed the glove box, definitely not behind there, sounds more like up by the windshield and rolling all the way across.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Could be something that is under the cowl then and will need to remove that after wiper removal.
S
seabas22
I think there is a screw loose in the ceiling. Really hard to locate where the sound is coming from. From driver seat it sounds like passenger side, but from passenger side it sounds like driver side.
Jacko1
I’m sure it’s a 10mm socket. Some robot at the plant is really sad today
S
seabas22
two phillips screws, not sure where they go. The overhead console does seem a bit loose now.
MarkD
I just had the same issue, my wife and I were arguing what side the rolling sound is coming from in the dash. Luckily, after searching this forum and a few other sites we discovered the problem is in the overhead console. A screw or screws fall on the backside of the overhead console cover. Let down the sun glass holder and pry the rear clips loose and sure enough I had a screw in my overhead console cover. Problem solved. There are videos on how to remove the overhead console on a Tahoe which will show you how to pry the cover off.
Phil Rosche
Thank you, had one screw in mine.
I realize this is a REALLY old thread, but, I had something rolling around in my overhead console and it was a black Phillips head screw with a built in washer. I couldn't tell where it went, does anyone know? Thanks.
AdrienR
