Thouse
Also today- general cleaning and trying to get this dash mat to lay flat before I put any sticky Velcro on my dash. Do any of you guys run these dash mats?
The A pillar passenger side trim was falling down. This clip was the culprit. I have nothing to clamp it down while I try to glue it so I am trying to glue the shit out of it without clamping. it’s worth a shot before I’d buy another trim panel.
C621BB86-269E-471E-BC46-D0B9C442F9E2.jpeg F1DBEE7C-F5C2-4EB2-8F01-77E4D0545C60.jpeg
I would be interested in that but I am not that handy... so if it’s complicated I’m probably not going to be able to do it ha
It’s simple, you just need to score a razor knife along the lines in the hvac housing and cut the plastic piece out, slide the filter in and then put the cover on and put a screw into it.
Found on Amazon but says it doesn’t fit my truck. Thought maybe I was looking at the wrong item
Pretty sure it fits, read the reviews where they talk about that. Here’s a YT video with links at the bottom for the Fram filter and the Dorman door separately. I did this to my 08 Silverado.
rgosart
Hey guys long time no talk. I polished my headlights the best I could by hand without drill and put in some brighter headlight bulbs.
Anyone have a recommendation for a rear floor covering on the cheap? (Rubber mat style) My hoe has no third row so it needs to be bigger.
I used a big rubber utility mat from Lowes. Cut it to fit.
Mezzo
Finally got the suburban up and running today,got a new 145 amp alty put in and some USB outlets with a volt meter installed, took it for its first maiden voyage in 4 months and it drove like a dream,could use some new brakes,i missed this thing.
Texas_Made
