Towing temp going up
97audia4
97audia4
You have a Tru-Cool 40k installed too right?
Yes the trans temp was fine 170 max mostly 165 at all times.
Coolant temp going up to 240 even in 4th gear or in tow haul mode on the highway . Might do the water pump in the parking lot of autozone tomorrow on the way home and see if that helps. The radiator is only 2 years old and coolant is fresh and clean . Yes it's dexcool.
97audia4
97audia4
The gauge is programmed to act like that so as not to send the soccer moms into the dealerships.
So it goes up to 240 with no warnings then too ? It held the temp fine at idle once we got got gas and fans were spinning loud . Idk why at highway speeds it would over heat if at idle it's fine and comes down
The gauge is dampened and doesn't move much between 195 (thermostat) and around 210. If it gets hotter it will certainly move that way. You might want to check the composition of your coolant, some folks find 60-40 water to coolant lowers their temperatures more than a 50/50 mix.
97audia4
97audia4
Water pump is original at 125k so it's more than likely not flowing it enough . Looks like I'm going to be doing a water pump at the racetrack . Need to make 275 miles home up some serious hills .
Foggy
KS
Has anyone found a high performance water pump for our apps???
I put in a new ac delco pump in march, and i'm getting hot while towing too.
Never thought about a water pump as I used a high quality one
willabea
