Overheated and leak8ng voolany6
Livebai8
Livebai8
Houston, Texas
I gonna check with the local Chevy dealer for these connectors... Rockauto, autozone, oreilley, Napa, pep boys don't have in a.c. delco...dorman is all and whatever else is listed on Rockauto.
02 TAHOE LS 4X4
5.3l FLEX FUEL
285/70/17 W/Z71 RIMS
Sent from my SAMSUNG NOTE 5 using Tapatalk
Livebai8
Livebai8
Houston, Texas
Got mine on Amazon. AC Delco.
Amazon only has the dormans...no d elco. I'm trying to stay away from the dormans
02 TAHOE LS 4X4
5.3l FLEX FUEL
Ok...thanks for the heads up on the fittings to the firewall...once I took the time and actually started to inspect the lines...this was stating me in the face!
I've noticed replacement fittings in black and white. What's the difference?
Also, it's a pain in the ass to remove!!!
02 TAHOE LS 4X4
5.3l FLEX FUEL
This is EXACTLY the same blowout that I experienced earlier in the summer. And yes, the so-called quick disconnect connectors are a MAJOR PIA to remove.
Don't waste your time on the quick disconnect connector release tools that you can buy at the auto parts stores, as they simply don't work (at least, they did not work for me, and I bought two different designs of tools, and they both failed). I used a hacksaw blade, and I cut though both ends of the thin plastic piece of the quick disconnect that bridges the supposedly quick release white tab, and I did this on both sides of each quick disconnect connector, for both the hoses and the Tees. Then, the quick disconnect connector just pulls off easily.
WARNING, use a set of thin gloves, when working in that area, or the insulation on the firewall just above those quick disconnects will get into your skin and itch like Hell for a few days.
I replaced ALL hoses related to heating, including the one that goes to the coolant reservoir, and I purchased them from Rock Auto. Good thing that I did, as all hoses were stamped with the original manufacture date of my truck.
I purchased the Tees from the GM dealer, at a high price, because I wanted to be sure that I did not have to perform this job again, as a result of substandard Tees (Dorman). I learned this from the folks here in the Forum.
Livebai8
Livebai8
Houston, Texas
Yeah...i just removed the right side first which came off way easier...it allowed me enough room to use my fingers from both hands to squeeze the tabs and actually pull it off. Which brand replacements did you go with?
02 TAHOE LS 4X4
5.3l FLEX FUEL
02 TAHOE LS 4X4
5.3l FLEX FUEL
In my post #26.
Livebai8
Livebai8
Houston, Texas
Livebai8
Livebai8
Houston, Texas
Ok cool..yeah!!! I missed that!
02 TAHOE LS 4X4
5.3l FLEX FUEL
Joseph, do you recall the part numbers for the end pieces that the hose slips on to?
02 TAHOE LS 4X4
5.3l FLEX FUEL
Livebai8
Livebai8
Houston, Texas
Success fellas!!! Turns out the hose connector that was on the white tee wasn't correct although it worked. I replaced with the correct hose connector which is white also.
Now just gonna drain the radiator and add the 50/50 back in there...i changed the Dex out years ago
02 TAHOE LS 4X4
5.3l FLEX FUEL
Candielaine
