BentleyArnage
Napa is spotty. If you can find an Auto Plus store, they have a lot of good parts.Do you know if NAPA parts are any good?
02 TAHOE LS 4X4
5.3l FLEX FUEL
285/70/17 W/Z71 RIMS
Sent from my SAMSUNG NOTE 5 using Tapatalk
02 TAHOE LS 4X4
5.3l FLEX FUEL
I'll double check the siteGot mine on Amazon. AC Delco.
Amazon only has the dormans...no d elco. I'm trying to stay away from the dormansGot mine on Amazon. AC Delco.
Ok...thanks for the heads up on the fittings to the firewall...once I took the time and actually started to inspect the lines...this was stating me in the face!
I've noticed replacement fittings in black and white. What's the difference?
Also, it's a pain in the ass to remove!!!![]()
02 TAHOE LS 4X4
5.3l FLEX FUEL
Yeah...i just removed the right side first which came off way easier...it allowed me enough room to use my fingers from both hands to squeeze the tabs and actually pull it off. Which brand replacements did you go with?This is EXACTLY the same blowout that I experienced earlier in the summer. And yes, the so-called quick disconnect connectors are a MAJOR PIA to remove.
Don't waste your time on the quick disconnect connector release tools that you can buy at the auto parts stores, as they simply don't work (at least, they did not work for me, and I bought two different designs of tools, and they both failed). I used a hacksaw blade, and I cut though both ends of the thin plastic piece of the quick disconnect that bridges the supposedly quick release white tab, and I did this on both sides of each quick disconnect connector, for both the hoses and the Tees. Then, the quick disconnect connector just pulls off easily.
WARNING, use a set of thin gloves, when working in that area, or the insulation on the firewall just above those quick disconnects will get into your skin and itch like Hell for a few days.
02 TAHOE LS 4X4
5.3l FLEX FUEL
Ok cool..yeah!!! I missed that!In my post #26.
02 TAHOE LS 4X4
5.3l FLEX FUEL
Well hell...i must not have searched good enough! I don't want to wait that long. I'm picking up from my local Chevy dealer closest to me.
Joseph, do you recall the part numbers for the end pieces that the hose slips on to?Ok cool..yeah!!! I missed that!
02 TAHOE LS 4X4
5.3l FLEX FUEL
