Transmission Towing Temp
Mikana31
It was hot yesterday and I was towing my horse trailer for about 3 hours, up and down some pretty significant hills. I noticed my transmission temp got up to 238 at a couple of points. The trailer is fairly high profile and, with the horse and tack, likely weighed about 4500#.
Tahoe is a 2013 SSV with the normal SSV options, 170k miles. As I am reading it, 238 is too hot. Any suggestions?
Thanks in advance!
Mike
GreyStone
Thanks in advance!
Mike
Did your SSV come with the HD cooling options?
GreyStone
It does, and Tow/Haul was on the entire trip.
Make sure your tires are at max inflation so they roll easy - and when it gets hot try locking out 5th gear, run in 4th - Curious , what size tires do you have?
M
Mikana31
I'd have to look to be sure, but they are what came on it when I picked it up from Denver PD.
Bob2C
Northern VA
I have an 18 5.3 6 speed with the max tow package and just got done towing a travel trailer with a dry weight of 4500lbs plus our crap. Trans temp in tow/haul mode on highway was 194-199 and occasionally got to 201 briefly when climbing hills. Nothing too significant. After I got off highway and did some in town driving temp went to 210, but came back down quickly once stopped and idling. I am running AMSOIL Signature in the trans if that makes any difference. I did not tow with it when I had ac Delco fluid does I can’t compare.
Bob2C
Northern VA
Decided to exchange some fluid only after towing. AMSOIL signature has about 4K miles on it and prior I did the full exchange (10 of 12qts) and filter. Didn’t know I was going to towing. This time I exchanged a little under 5.5 qts.
here is what I would do
1. drain the coolant, flush it real good with just water, put in some chemical flush and straight water, run it for at least 15-20 minutes or up to 3 days.
2. drain it, flush it with straight water again, yank the radiator out and install a new one and dexcool.
3 install a tru cool 40k (inline, not bypassing the radiator), if it has a external trans cooler yank that and throw it away (the tru cool replaces it)
problem solved.
Mazer16
