GreyStone
Quick question:
How long ‘yall going between oil changes on Mobil-1?
I am at 4,000 and down 1/2 quart. Oil still looks golden color.
How long has the oil been in the engine months wise? With synthetic you can go at least 7000 mi. if you top up with a half quart of new.
GreyStone
Ok when I run this jumper from tan to blue on the wiper plug it works. The button and the key fob open the glass. Not sure what to do with the pink/black wire for the glass ajar signal.
Be careful Bro....you don't want this to become one of those trucks that spontaneously catches on fire while parked somewhere.
osiris94ej
Casper Wyoming
Deleted the resonator on my Escalade tail pipe section. Kinda like the no tip/hidden look.
Sent from my SM-N950U using Tapatalk
GreyStone
About 5 months. Didn’t write down the date.
From the Mobil 1 website - "Mobil 1 Annual Protection motor oil helps extend oil life, delivering proven engine protection for one year or 20,000 miles between oil changes, whichever comes first" The most generic standard Mobil1 is 10,000mi or one year. But with AFM engines always top-up to full.
PG01
Up here to the right
Yeah, **** that... 3k-4K max synthetic or not I don’t gaf
GreyStone
Yeah, no way I am going 10,000. I originally figured 4,000 and am at 4,257 or so now.
Really no good reason to use synthetic if you change your oil that frequently. Very old school thinking from when everyone used single weight oils.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I was on the fence about using synthetic but with such a low mile truck that I plan to have for a good while I wanted to use some of the best oil I could. I ran synthetic blend in my last suburban up to 248,000 and it still ran strong when I traded it. I am considering doing the same but I changed it three times a year with 3,000 mile increments at the rate I drive. I was hoping for two times on full synthetic.
I run 13k-15k miles OCIs on my Burb with Mobil 1 15K mile oil... Blackstone says I could go further if I wanted to but my oil system isn't stock either.
Wow! That’s pretty impressive :eek:
Phlipnstik
