2015 Tahoe..Truck Hesitation
M
mnjeepmale
This sounds like you're describing transmission jerking. It's the torque converter locking/unlocking repeatedly. Have your trans fluid flushed and filter changed. Problem solved.
I just changed the transmission fluid and filter about 2 months back. I'll change it again. Going to try cleaning the TB and maf as another suggestion.
Blkdout07
I would also say clean your MAF sensor and throttle body. Just make sure to get the specific cleaner for each. I had this problem recently and that did the trick. Takes 30 minutes
Mark Shipley
I had the same behavior pattern with my 2004 Yukon Denali XL a little bottle of perfume and it turns out one or both of the front hubs was actually binding and they're pretty famous for that. I've had three of these trucks and they tend to go out about every hundred thousand or a hundred twenty five thousand miles.
PG01
Up here to the right
Forget the perfume comment the damn TV pick that up
Lmfao... I thought you sprayed a little bottle of perfume on yer hubs and they got all fixeded up....lmfao
Plimbob
Des Moines Iowa
My 2017 with 78,400 on it does that predominately in 1st and 2nd gear. I have cleaned the TB, MAF, changed air filter, changed trans fluid and filter. Still doing it. I checked for codes but none. I was thinking of taking it in to a trans shop to have them take a look.
Rather annoying.
M
mnjeepmale
Well I cleaned the TB, MAF and changed the tranny fluid but the issue is still there. I can still feel a slight jerk when accelerating. Wondering if it's the tranny now.
TorqueToSpec
Washington, DC
Rather annoying.
I have roughly 83k and notice this exactly. Hesitation predominantly in 1st and 2nd. I just had a transmission flush and they noted a dirty throttle body.
You mentioned being on the highway, so I am assuming not 1st or 2nd gear but more generally. Any mods on the tranny with a tuner? More pronounced at specific shifts? In my research so far it seems that you are almost EOL on that transmission, and (for me) I am still investigating if it could be torque converter, or even the transmission fluid.
Plimbob
Des Moines Iowa
I just finished a tune on my 17 and haven't driven it much so I can't say yet whether the tune eliminated it or not. More on that in a few hundred miles. The way it felt it seems like it might be the torque converter.
You state based on your research the trans may be at EOL at 80,000. Why did you come to that conclusion?
Thanks,
Tim
Thanks,
Tim
I was wondering the same thing.
M
mnjeepmale
So I took my truck to the shop for diagnostics and they looked for leaking vacuum leaks and pulled the plugs and test drove the vehicle with the computer hooked up and it shows random misfires on several different cylinders. So I had them put a fuel injector cleaner in the vehicle and will drive it for a week to see if it goes away. Not sure what else it is.
Plimbob
Des Moines Iowa
Dan, FWIW, I have had one on my 07 for 3-4 years and hasn't failed. If you think it may be causing issues you can send it into back to the manufacture and have it tested. Depending on when you purchased you may want to check for a firmware update to it?
I have 296,000 on my 07 and once in awhile I will get a misfire in cyl 1 & 7. I checked the coils and they are OK. I just replace the plugs and it runs fine for another 15-20K and then one of the two will start acting up and I replace. BTW, they never look fouled,etc. I have no idea why it happening but its a cheap fix.
Hope that helps.
Tim
M
mnjeepmale
Hope that helps.
Tim
Thanks Tim.
Well it's very bad now. When I drive it's continous jerking and very noticable. I feel like the engine is going to die. Still don't have any check engine lights.
I have unplugged the AFM and I think it's worse. So I can rule out the AFM disabler.
The truck is in the body shop for hail damage repair then going to auto repair shop right after.
Plimbob
Des Moines Iowa
Have you checked with a reader to make sure there are no codes? It is odd that it would be running that poorly and its not throwing off codes of some kind.
M
mnjeepmale
I took the truck to the shop and they said I need a new engine.
This is what they said.
Removed spark plugs and found residue of oil on them, spark plug is within gap at this time. Removed the air intake tubing and found puddles of oil inside. Proceeded to inspect the intake manifold and there is oil washing inside. The oil going through the intake is causing spark interference. Performed a crankcase pressure test and there is a small amount of vacuum in the lower case, this indicates a problem with the upper engine allowing oil in, would have to disassble the upper engine to find the source of the problem.
Oil in the combustion chamber and not allowing proper detonation will damage the converters. The rear oxygen sensors are sticking around 700 and the range should be 100-900 mv. This is a sign that damage is happening.
THERE IS A TSB TO REBUILD THE ENGINE FOR THIS PROBLEM
I was quoted $10,000 for a new engine. I'm bringing it to another shop to look into this. They gave me the TSB number but this is crazy that I need an engine.
Sent from my SM-N950U using Tapatalk
PG01
Don’t you dare pay 10k for a motor for that truck
Bentley95
