2008 Yukon Denali. What are these parts from the rear glass called?
ZK686
My back glass doesn't open, I took off the back inside panel and noticed this mechanism. When I push the rear glass button, this little plastic piece is supposed to pop up and push the metal arm in, which unlatches the back glass. But that little piece is getting stuck, it's trying to go up but it just kinds of moves a little up and down. I'm assuming I have to buy that whole unit. What is it called? Also, I took out some clips from the inside panel and broke them. Anyone know what the clips are called? I attached pictures. Thank you!
https://imgur.com/a/ZDsj22U
GMT800 2005 Tahoe Z71
Navy Supporting Member
Could you have sprayed some lube in there for the latch to release?
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. While you may have posted pertinent info in your first post, you may forget to do it again and the info is needed by us anyway. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Korbin_A
