Norcal_ss Lowering Kit Warning
NORCAL SS
SUV SUSPENSION GURU
Oh output shaft I've had break when going so low because driveshaft gets pushed into trans. This is why I have the bars.
If there's anything I can do to help yah I have open ears.
Thank you
Kee Fuller
las vegas
I'm not sure what you have. I ordered Belltech 4922's, they're listed as 1.26", I have yet to bottom out the shock or bumpstop though. There is a hole on the bumpstop pad on the axle already, I just bolted them on there.
I have the 5305 rear springs. The bump stops that were included dont have anything you can bolt into. I did the free travel mod and it bottoms out when i hit a bump going fast. I googled the bump stops you have. Those should work. Good looking
randeez
south florida
Thanks for input
1. Gm used 2 different tabs above panhard mount drivers side so you trim the lip left over on the mount not upper crossmember
2. Bumpstops bolt thru the holes already on axle pads. Also can cut down for more clearance
3. Im around 24/7 text 415 519 2432 im sorry you feel I ghosted you but im here.
next time....why dont you call me when i need something to save me the trouble, k pal?
:cheers:
NORCAL SS
SUV SUSPENSION GURU
Shoot me a text like I said 24/7 and I have no problem with feedback good or bad
I'm not perfect but i will try to fix a issue if you feel wronged
NORCAL SS
SUV SUSPENSION GURU
And not tb springs . These have my name on them.
Also I set up spring rate and have them made to my spec
Fosscore
what bumpstops did you get? I didn't know i need ones that have to be tapped in. I thought the ones that came with the springs would do
@Kee Fuller
Ended up cutting down another 1/4" off the top of the bump stop. Not sure if this was what you were looking for?
NORCAL SS
SUV SUSPENSION GURU
You can cut rear stops down. Many customers i have do 26s and aggressive offset. So i have the stops set up where it hits begore tire hits lip or if your clear you can cut it for more travel.
2016YUKONSLT
I bought Tony's kit in December 2016/January 2017 and installed in March 2017. It came with instructions, and I watched the youtube videos that I found on YT. I had zero issues until the phr bar bracket. I was able to figure it out. I did have an issue with the alignment. In September 2017, I needed a set of tires that I put on at the same time I did the kit. The alignment was still an issue. I sent Tony a message and he said take some pictures of it and was able to diagnose the issue through just pictures, something the GMC tech that was doing the alignment, couldn't.
Dc78
Good to know. I was wondering the same thing. Was gonna get the 4/6 kit and asked a couple questions and just got a reply ....not in stock. No estimate on when more will be in or addressing the other questions. Maybe I’ll just go through belltech or get the Reklez kit. Hopefully the service is better but then Again I notice a lot of business are like that now a days.
BlackedOutHoe
Low & Slow
S. Carolina
Had I not got a great deal (easily 20% off msrp) I would have gone through Amazon to get my Belltech kit and Spohn directly. But, if I was on a time crunch, def would have pursued another avenue than Tony, unfortunately.
Dc78
I’m thinking of going to spohn directly and getting the drop kit from Sport truck pros
Fifty
I think the comms bit is hit or miss. Some have great luck and fully recommend him etc.
others have had bad luck. I fall under the bad luck. I’m just lucky it was the bad luck trying to get info to make the purchase. So I didn’t.
As for “bolt on”... I’ve worked with a couple companies over different platforms. To be bolt on it may require drilling a hole but never cutting.
and if there was drilling or cutting, there was always a template made and included.
but back to what’s important, comms are a hit or miss
Wolfpack79
I didn’t want one of my first posts to be negative here but, his communication is definitely something that needs work. I’ve texted the number he’s given twice and PM’d him here and still no response. I think I’ll take my business elsewhere.
I don’t blame you. He used to have excellent customer service but maybe he’s gotten too big and can’t take care of his customers anymore, who knows. I have seen it too often with a small business that gets too popular.
Fifty
At some point business’s need to accept the growth and invest in expanding... and staff.
and sadly in California that is stupidly expensive.
Or the business needs to reel it in and get back to basics
albac
