cfmistry
A nice drop would really set this off
I agree with you, just can't bring myself to lose the ground clearance (I bought the truck to drive in the snow).
Looks real good...
Thanks!
Glad you found the cause. The forces the suspension sees would surprise you so getting the bolts torqued properly is very important. I would make sure you get it in for an alignment check to make sure things didn’t slip out of position.
I guess you are right about that! The clunk is definitely gone, I've been driving it all week and not a single noise.
PG01
Up here to the right
I thought it did. I also thought I set it in the DIC. However it’s not working and what would cause it to do so? Think a factory reset will help?
Can’t hurt to try.... sucks to reset everything else tho. If that doesn’t do it maybe disconn batt for 15-30 min.
Kee Fuller
las vegas
Thanks!
Adjustable coilovers that go up with a turn of a wrench in the winter that bring it back to stock height ;)
St. Louis
When the doors lock automatically after a time the last door was closed.
Mine only does that when I press the lock button on the drivers door when getting out. It dings a couple times when pressed, then 5 seconds after last door is closed they lock.
EDIT: Found it, called Delayed Locking in the manual
On my Silvy that sets the alarm too. I found out when I did that and the hood wasn’t latched, and I opened the hood. Did a mad scramble for the keys.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Gave her a wash. Solved my front suspension clunk, one of the upper control arm bolts was only torqued to 70-80ftlbs. I wouldn't have though that torque would let it clunk, but once I got it up to 130ftlbs the noise disappeared.
I haven't found my clunk yet. Going to have to take some time tomorrow and check a few things. I haven’t been able to duplicate it yet and it’s not consistent. Gonna check bolts and lube the sway bar.
Have you checked end links?
CHOO CHOO
BackPagePhil
Manheim, Pa
Finally washed the Tahoe after a VERY long time. Yeah....rock chips everywhere. All over the hood, and even found some chips on the passenger side door. Front bumper is/has been shot(clearcoat) so that's another thing.
Honestly not sure what to do. We have been looking at trading in the 09' 4door jeep we have and have been looking at alot of different vehicles. Telluride, explorer, traverse mainly. Would like to get another tahoe/denali of my gen, but she is skeptical about getting a high mileage vehicle (anything over 100k).
I don't want a high monthly payment so the k2xx is probably out of the question.
Not real sure what I want to do. My Tahoe will stay with me until it falls apart or I need a new engine.
Only looked at them to verify they were not broken. I have had one apart for a CV axle swap.
I would check to see if they move when you yank on them with the suspension hanging just to eliminate them as the source of the clunk. And while you’re there check everything else for movement.
Just scored these on ebay for 60 bucks. The ones on my truck are aftermarket and it feels like im gonna break em each time i pull on my door. I should have just had my original textured ones sanded down and painted em
https://www.ebay.com/itm/363042370084
That’s a score! The OEM ones are nearly that much each iirc. And my friend that owns a body shop won’t even touch the aftermarket ones anymore because they just break in no time.
5strmtrp
I believe it was a small stone stuck in between the dust shield and rotor
well, tbh, i live around the corner from a town called Pine Bush in N.Y.
Look it up.... lol... lots of ‘believers’ over there.....lmao
lived in Goshen for half a year. No offense to anyone but to say the least it was interesting!
Have property in a lil town of Narrowsburg. It’s on the PA side of the Delaware thou.
5strmtrp
Trucks been running a bit rough the last few weeks. Changed plugs n wires in the beginning of the pandemic. Wife has been driving it recently. Got in it yesterday, check engine light P 0158. Changed out that o2 last year. What the heck..
George B
¯\_(ツ)_/¯
Had it up today and checked the upper control arm bolts. All four took a half turn before my torque wrench clicked at 148 foot pounds. Everything else is tight.
took the sway bar out and found a buildup inside the bore of the bushings and rust buildup on the pad of the frame between the bushing and the frame. The bushings were sort of galled to the sway bar and should be replaced soon but in the absence of parts I lubed them up with spray anti-seize and put everything back together. Now the sway bar moves smoothly in the bushings. Fingers crossed.
St. Louis
Picked up the 3m eraser wheel and changed out the rear GMC emblem.
It's freaking hot to do anything else, mid 90s with high humidity.
My 2011 had the black GMC badges front and rear and I really liked the look. If I would've known how easy it was to remove the front grill emblem I would've done it while at the salvage yard removing my other belongings.
JasonW4141
