Arnott conversion bypass install
rollinjoy
I installed the Arnott Autoride conversion kit on a 2002 Yukon Denali xl. Now I can’t find where to wire the bypass module for the kit. Where is the air suspension controller located? Instructions say it’s in rear right side of cargo area. I can’t find
GreyStone
Go ro 6.50
R
rollinjoy
I watched that video already. That seems to be on a newer model. Mine is 2002 Denali xl
The controller is behind the right rear panel in the cargo area. You have to pull that big panel that covers the rear hvac unit under the window. There’s a computer that controls the air suspension with 3 plugs in it I believe.
R
rollinjoy
That’s exactly wat the instruction says. But I can’t find it. Is it the side where the jack is or passenger side? I looked on driver side. May be I’ll pull both sides out. Thanks
Ummm....the right side. As in passenger side. Driver side is the left side of your vehicle.
R
rollinjoy
Found the controller. Thx. Now does anyone know Which one is pin D and pin E on the gray connector. And pin B-8 on pink connector. Those are the 3 wires I need to splice into
Here’s the grey connector. D is the orange wire, E is the black wire.
I looked at Arnotts instructions and couldn’t believe their pictures didn’t clearly show the pin outs or even mention the colors of the wires.
R
rollinjoy
Instructions from arnott says B-8 pin but there is no b-8 pin being used on my pink connector.strange. Only pins used on B side are 1,3,4,5,6.
1-lite blue/white stripe
3-lite blue
4-gray
5-brown
6-white
3-lite blue
4-gray
5-brown
6-white
You’re looking at the connector from the wrong end. I believe you’re looking at it from the rear where the wires exit. If you look at it from the front of the connector it will make sense. That’s what the picture in the diagram shows- at the upper right is the 3 dimensional picture showing the correct orientation of how you’re supposed to be looking at it, then below is the picture showing PIN numbers. I imagined you looking at the back side and you’re looking at it upside down and backwards because then A12 is what you think is B1 ( lt blu/wht) and what you think is B3 is actually A9 (grey which can look like lite blue) etc. Try again, looking at the front of the connector and oriented like the picture.
Ok good, glad you figured it out. That’s why I included the pictures.
steelersallday30
Hey brotha I have a 2003 Yukon xl Denali was the air control module there in the passenger side? Was it easy to install? And is it easy to take off the panel? I can’t find video any where
wjburken
Eastern Iowa
The link to the video is in post #2 of this thread. Worked for me just now.
steelersallday30
Hey brother how did the conversion kit work out I bought part number c-2667 I’m hoping it works well and is a good product
AdrienR
