Tru-Cool Max 40k Transmission Cooler
Jlaughtr
Jlaughtr
Deming, NM
Uh, concerning what that guy in that video says about the mounting position.....
Cold fluid is thicker than warm fluid, thus why it will only run in the first few larger tubes when it's cold and you don't need all the cooling surface. As the fluid heats up, it thins and flows through the smaller tubes and utilizing more surface.
Kind of an internal thermostat for the cooler.
As for bleeding air, he said it's an open system with a vent and fill/dipstick tube, SO WHAT? It doesn't have to be a sealed system like the cooling system. The engine crankcase is an open system also. There's air in the oil passages, and on top of the heads under the valve cover and when the motor starts it has to push that air out so the oil can flow/drain...what a moron, lol
the small factory one is mounted with the fittings down. I don’t know much about it so I figured I’d post the video but if the website says any way then down is the most natural for the oem lines
Found this video explaining that this cooler should be mounted with fittings up. Start at about 27-28 sec
You can find just as many videos stating the exact opposite too. In all reality, real world testing it does not matter. The instructions explicitly state it can be mounted in any position and in fact I actually got through to the tech department at Tru-Cool due to all the people who think they’re internet engineers and post videos like that. They stated indeed it does not matter. If you look hard enough you’ll find the guys who tested them in both orientations and compared trans temps during the exact same conditions and proved it doesn’t matter.
08z71bgm
Long Island, NY
I was skeptical about it. Logic was there but then I figured I’d check the manufacturer and sure enough it states any way you want it’ll work.
S33k3r
Dallas, Texas
I do have the RPO code on mine and my cooler is right up front, just behind the grill. I also have code GT4 for the 3.73 gear and I bet that is why I have that cooler.
Did the transmission cooler come standard with the GT4 RPO code?
GMT800 2005 Tahoe Z71
Navy Supporting Member
I don't know but it makes sense that with a 3.73 gear the Tahoe could be used more for towing and therefore the trans cooler. For all I know the same trans cooler could be on all rigs with 3.42 gears and the 4.10 gears.
Jlaughtr
Jlaughtr
Deming, NM
I just looked at my build sheet again. I don't have the GT4 RPO, but I have GU6 which is the 3.42 gears.
I also have this code which explains the Trans cooler:
Z82 - TRAILERING EQUIPMENT INCLUDES: * TRAILERING HITCH PLATFORM * 7-LEAD WIRING CONNECTOR * TRANSMISSION OIL COOLER * HIGH CAPACITY AIR CLEANER
SUP SR
About a week ago I was towing a 16ft trailer with a 2-seater Polaris Rzr loaded on it. I was driving from NM to AZ and it was freaking hot. Around 105 degrees. As I was driving, I saw a cloud of white smoke shoot out behind my Tahoe. I pulled off at the next exit and looked underneath as best i could since the ground was 120+ degrees. I found a large amount of oil on the passenger side and it looks like it got on the exhaust and that's what burned it up. I checked the oil filer and it was good. I checked the oil level and it was good. I limped it the rest of the way and made it to a shop. The oil underneath had dried up, but they came to the conclusion that it was tranny fluid that shot out of the overflow port. When they check the tranny fluid the mechanic said it was damn near boiling because it was so hot. He recommended I get an larger external trans cooler.
I've searched around on the forums and haven't seen much about external trans coolers. Just wondering if anyone has installed or has any good info about them.
Thanks
SUP SR
I just installed about a month ago a Trucool 40k on my 2002 Chevy Tahoe Z71, 5.3L (260,000 miles, first owner). I also had previously installed an instrument cluster from a 2001 Yukon Denali which has a transmission temperature guage. The result of the new transmission oil cooler has been a 40 degrees drop in temperature. Lately it as been around 100 F in the Houston area. My transmission temperature never goes above 150 degrees.
Jlaughtr
Jlaughtr
Deming, NM
Did you bypass the radiator or just plug and play the new cooler and use the original trans cooler lines?
1BADI5
DMV
The highest trans temp Ive seen since installing the 40k and deep trans pan is 140* when the heat index was right at 100*.
So with the larger cooler and trans pan I have about an additional 3.5 qts of DEX6 in the system now......it helps.
Key to GM transmissions lasting, especially if you're towing......fluid and filter every 30,000 miles of every 2 years. That's what I do and I have never had one fail on me......that also includes several 4L60s
SUP SR
I used the original lines and connected the cooler to them using the rubber hoses provided. Also attached the cooler by just drilling a couple of holes and using the small brackets provided. No need to buy additional brackets. Installed it with the input and output on top.
Tim907356
I hope you don't mind a post, but I just installed a TC 30K cooler, because it fit better between the beams, behind the lower grill. I left the rad. and external coolers in place, and plumbed it in series with the hose they provided; just cut the factory aluminum line and clamped the hose to the open ends. I still see ~160F on the gauge, but that's down from 185F in similar conditions.
I took mine in for service after that (flush and filter), and the guy said that one reason they overheat is b/c the torque converters go bad. I noticed with mine the transmission stutters off-idle, and over-rev's when it engages. Sometimes is a little rough at stoplights and such as well. Pulling a 5k# camper, I figured I'd just replace the TC, so its going in tomorrow....but with the 6sp., it's $1700!!
...sorry: 2010 Yukon Denali XL, 130k mi.
latvius
Ariton Alabama
I used Glenns bracket on my Denali and the other one of that forum you referenced for my Tahoe, Glenns hands down is the better buy. The guy from the forum took forever with no communication and I thought it was supposed to come with the fittings maybe I was wrong on that part I don't remember well enough. What I do remember was wondering if I just gave my money away.
Glenns bracket comes with quality hardware and easy to install instructions. I used the compression fittings on both installs keeping the factory lines with the factory quick disconnects.
Expect to be about 30 degrees cooler running temps.
Buford bubba
