Nav radio upgrade.
St. Louis
Yes, when you order it you submit your vin and they code the DVD with it. When you insert the DVD and it starts the install, it verifies the VIN locked to the radio before installing the updated maps.
I'm sure it's just info in a file coded on the DVD and could be hacked, if someone who's into programming is inclined to do it.... lol
Luie
Luie
Well after looking and looking for the 2012-2014 HU I found two. And bought one of them today and will probably buy the other one on the way home next week. Gonna upgrade the wifeys Tahoe AND my dirty Max.
petethepug
Michael
SoCal
FYI, the mini USB cord (at the back of the unit) for these hard drive units has a different shaped profile than the standard cord. Make sure you purchase the one specifically made/sold for this head unit.
Congrats on finding one of those little suckers.
08grey
Were you able to update?
Sent from my SM-G973U1 using Tapatalk
Luie
Luie
When this hitch ends tues and I head home for my 7 days off Im gonna start the process of installing one of them in my wifes tahoe. Gotta send them off to get 'unvin' locked first. Ive found several places that can do that online. Yet to pick one tho...
Gotta mount the nav antenna then I can install the DashSkin then speed sensor wire, rear camera wire etc...
Luie
Luie
Also get two of those mini usb wires too.
Luie
Luie
I need some sources for this cable now. Just a part number would be great...
08grey
The Bose A2DP streaming module handles music streaming and integrates seamlessly into our trucks. The older version operates off 5V aka USB power source too. It allows your phone to pair up to the trucks oem BT & A2DP simultaneously. The Bose will pause the music and resume when a call comes in via BT. It’s quite a marvel for being almost a decade old and has no finicky issues pairing up.
I’ve had too many smash & grabs over high end audio equipment to go down that road again. As far as VIN locking, nothing is VIN locked on NNBS anymore with Vendors offering unlock services or inexpensive, cloned Tech II available.
Wait, the 12-14 NNBS Navi update DVD for HDD units is one time only VIN locked to the head unit?
Have a link to said bose device? Sounds cool
PG01
Up here to the right
This is the one I bought, to plug into radio with some stupid wire clip on the end to fit radio. On my 13 it goes under console to console box. It meets up to another cable/usb connection under cup holder and continues to white usb ‘outlet‘ in console box.
I have this which is factory set up..
but you can use anything like this
Luie
Luie
Not quite sure how I pulled it off but ended up with 2 2012-2014s and 2 2007-2011s.
I like that usb cig lighter port...
08z71bgm
Long Island, NY
Curious....what is the difference between the two nav HU. I have nav in 08. DVD in second row. I would rather upgrade to an alpine unit and retain dvd playback for the rear. Really wonder what is the benefit of the later oem model vs an aftermarket upgrade and get AA/CarPlay as well.
PG01
I did upgrade to 2012 + just for factory looks. Money is better spent on aftermarket imo
Luie
Luie
I understand if you didn’t have nav and wanted factory nav. Either way you suggest swapping for aftermarket huh?
To me if you are not in a hurry to make this swap you can take your time and find a GM nav radio usually pretty cheap. When I made this swap in my truck I think I ended up with about 200$ in it. Since I took my time it didnt hit the ole pocket book hard all at once.
PG01
If you want aa/ CarPlay etc, access to torque pro app etc... yes. Factory look then oem. I guess it’s a personal choice.... my opinion anyway....
XJ_eep
Has anyone here installed a Kenwood 7 with Bose and Navigation?
Does it still function properly with the 2nd and 3rd row DVD screens?
Can you get the right adapters for it to mate with the steering wheel controls?
Does it have an input that I could connect to wirelessly via a WiFi link in order to screen cast to the rear screen tv's?
Is there any head unit out there that does do all these things and I'm missing it?
I'm looking at the Kenwood 7 because it seems to be the closest to giving me all the options I want while still having Android Auto.
Luie
Luie
Ive got two newer radios now. Also picked up an AutoSync from BTDieselworks that can do an un-vinlock. Plus tons of other things.
Conedaddy
