Rear Differential Fluid Change
jakcol997
Hey guys! I noticed my rear diff is leaking a drop or two, so I decided to change out my rear diff fluid. My question is, what weight to I need to get? Also, from compline.com it says I have 3.73 with positraction limited slip, and ive read I do and I don’t need the additive.. anyone change their rear diff fluid have any opinions? I need help
wjburken
Eastern Iowa
If I’m not mistaken, that vintage of truck takes 80W-90. Do you have an owners manual?
HiHoeSilver
Away!
Chicago
I'm guessing that info came from your RPOs? Gt4 and g80, I believe.
Plenty of opinions on the friction modifier. I believe after all of the back amd forth I've read, the AC Delco spec fluid or the Royal Purple have it in the mix already. You're going to hear a few different things about this.
jakcol997
jakcol997
Yes! I bought the 5 RPO look ups for $5.. can’t look up my 14 RAV4 though! But that’s all steale
yes, gt4 and g80. The guy at Oreillys told me 75w-140... that seemed off cause I haven’t read ANYONE using that one.
HiHoeSilver
Away!
Chicago
Should be in your manual, which you can download if you don't have.
Is it 4wd? The front and rear can be different, too.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Use a full synthetic 75-90 or 80-90. I had good luck with a finicky G80 using amsoil. Is expensive but you
Don’t change it often enough to be cheap.
Edit: like @HiHoeSilver said. Check your manual or share what truck this is.
derekrcannon
